Brake issues...Day 4 - JeepForum.com
post #1 of 5 Old 07-26-2013, 08:33 PM Thread Starter
Jcarney1200
1975 CJ5
So I have been asking questions pertaining to my drum drum set up on my CJ 5, I have replaced the lines, bleed the MC, attempted to vacuum bleed, gravity bleed, etc. The MC is bleed and when I attach the brake lines and pump the brakes nothing comes out nor does it fill the lines. I am scratching my head as to what else could cause this problem. If anyone has any advise please I am open for anything thing. Oh and I have checked the push rod and the depth of the bore.
Jcarney1200 is offline
post #2 of 5 Old 07-26-2013, 09:25 PM
row684
Is your proportioning valve working/plugged up somehow? Does the pedal feel firm or just go to the floor? The master could be bad, wouldn't be the first time a new one was defective.
row684 is offline
post #3 of 5 Old 07-26-2013, 09:36 PM Thread Starter
Jcarney1200
1975 CJ5
I wanna say yes, I took a look at it. Yea it might be the MC, but when I bleed it with clear tubes going from the outlet back to the reservoir, it appears to be moving fluid just fine...this is my quandary!
post #4 of 5 Old 07-27-2013, 07:59 PM
Fourtrail
1974 CJ6
Try plugging the mc outlets and see if you get a hard pedal. Might push enough fluid when looped back into the mc, but then is bypassing when there is any good resistance.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #5 of 5 Old 07-27-2013, 09:03 PM
LumpyGrits
Are your brakes adjusted properly?
If not, do so.....
LG
LumpyGrits is offline
