Brake Issues CJ5 - JeepForum.com
post #1 of 8 Old 09-03-2012, 03:10 PM Thread Starter
yardornament
1980 CJ5
Brake Issues CJ5
Everything brake related on my 1980 CJ5 has been replaced. I have gone through several bottles of brake fluid and used several methods bleeding them but in the end its always the same outcome no pressure. It only takes several pumps on the brakes to get good pressure but I know that it shouldnt be like that. Could anyone tell me what the problem may be.
Overhauled front and rear brakes, replaced proportioning valve, all new brake lines, new master cylinder. I just dont know what to do to fix them
yardornament is offline
post #2 of 8 Old 09-03-2012, 06:01 PM
80cj
80cj's Avatar
1980 CJ5
It's possible to position the front brake calipers so that the bleeder screws are not located at the very top position. Check that. Remember that air will find it's way to the top. If the bleeder screw is not positioned there, you can pump forever and you will not bleed all the air out.
Also, did you bench bleed the master cylinder?
80cj is offline
post #3 of 8 Old 09-03-2012, 06:35 PM Thread Starter
yardornament
1980 CJ5
I didn't personally put the master cylinder on so it probably wasn't done correctly. I will have to pull that off and give it a shot.
post #4 of 8 Old 09-04-2012, 03:10 AM
RWise
1981 CJ5
If the rear drum brakes are to far out of adjustment (to much gap between shoes and drum) you can get the same, have to pump up the brakes.
RWise is offline
post #5 of 8 Old 09-05-2012, 04:46 AM
Hawk4097
Also Master Cylinders have been known to bad even new ones. If you cant bench bleed it out and fix it. I would return the cylinder and get a new one.
Hawk4097 is offline
post #6 of 8 Old 09-05-2012, 05:51 AM
adman02
1979 CJ7
This.
I've read several posts on this forum where people have reinstalled their front calipers on the wrong sides (passenger caliper on driver's side and vice versa). It's a common mistake that makes bleeding impossible.
adman02 is online now
post #7 of 8 Old 09-05-2012, 09:38 AM
Manhattan
1981 CJ8
Originally Posted by adman02 View Post
This.
How can you tell if they're on the wrong side? Just crawled under... bleed valve is facing the back, at the top of the caliper, an inch or so higher than the brake line. Wouldn't it be upside down if switch L vs. R?
Valve clearly at the top. That spray is left over from the 1st of 3 bleeds.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #8 of 8 Old 09-11-2012, 03:01 PM Thread Starter
yardornament
1980 CJ5
Calipers were definitely on the wrong sides. Swapped them up and brakes work like a charm now. Thanks for everyone's advice.
Having some brake issues... Ruthless1 Jeep CJ Forum 3 04-09-2011 10:25 AM
Brake Issues joerob25 Jeep CJ Forum 10 03-31-2011 10:07 AM
have brake issues ValerieOES Jeep CJ Forum 6 10-15-2010 09:54 AM
Still having brake issues. 78treehugger Jeep CJ Forum 6 06-24-2009 03:37 PM
79 cj7 brake issues Southern Comfort Jeep CJ Forum 6 03-18-2003 07:56 PM
