brake help on cj5 - JeepForum.com
post #1 of 3 Old 07-24-2009, 06:27 PM Thread Starter
tonsoffun_77
1977 CJ5
brake help on cj5
I have a '77 cj5 renegade, and this certain model was supposed to change to disc brakes in front in '77 but i guess i got a real early on, my question is the parts store is asking what size,
Front
10x1
11x2
Back
10x2
11x2
On the side of the drum, there is numbers saying maximum diameter 11.060 in
on front and back drums
Is the 11x2 the right shoes.
i need to know asap changing brakes tom..
thanks
'77 cj5 renegade 304 V8 3 speed
tonsoffun_77 is offline
post #2 of 3 Old 07-24-2009, 07:11 PM
carguy68ssrs
1977 CJ5
sounds like you have 11x2 drums front and rear. the max diameter is for when they machine drum when you replace shoes so they don't machine drum too thin. Buy the 11x2 shoes and then just hold them up to the old ones before you take them off. Do one side at a time so that if you forget where some thing went you can always look at the other side to make sure you are right
carguy68ssrs is offline
post #3 of 3 Old 07-26-2009, 01:09 PM Thread Starter
tonsoffun_77
1977 CJ5
thanks carguy,
i went with the 11x2 and worked great.
Emergency Brake Hand Brake in a CJ7 with Fiberglass Tub asjordan Jeep CJ Forum 16 08-22-2010 06:50 PM
Front E-brake cable 1" short of the Brake Bracket huntin cj Jeep CJ Forum 4 05-01-2009 04:48 PM
brake/pedal/brake switch adjustment atom73 Jeep CJ Forum 1 07-13-2007 10:27 AM
brake fluid or gear oil in brake drum tr6 Jeep CJ Forum 8 09-20-2005 07:27 PM
yj brake booster on a manual drum brake cj5? 77 renegade Jeep CJ Forum 2 02-12-2005 06:17 PM
