#1 | |
brake help
i am now the owner of a 75 cj5 and it is awesome. it has stock 30 and 44 axles with 4.27 gears and a detroit and lockrite. my help is in regards to brakes. can these axles be converted to disk? what is the best way to do this?
2000 XJ 4.5" lift 35 inch BFG muds 75 CJ5, 360 v8 with hei distributor, dana 30 front with lockrite, dana 44 rear with detroit, 4.27 gears, twin stick, T18 4 spd and lots of goodies. Just sold 94 YJ, 4.0 I6, 2.5" springs. 2" shackles, 33x12.5x15 muds, 31x10.5x15 radials, 4.10, hand throttle, sweet ford 8.8 with disk brakes and 4.10 LSD for less than $200 |
#2 |
I'm in the process right now... got a dana 30 out of a '77 CJ7, and the plan is to swap the knuckles... I am just waiting to get time--will end up taking the knuckles in to get new ball joints put in. Fairly simple, straight forward. You have to work the front port of the MC to work with the discs, but it is straight forward as well... I think there was a write up on it in JP Mag, I will look around to see if I can find a link for you.
... I guess I'm gonna have to fix that too……. 1974 CJ5 BUILD THREAD 1974 CJ5 BUILD PHOTOS Bumble Bee The TJ |
#3 |
Converted my '75 Dana 30 to discs using '77 rotors with Chevy calipers and caliper mounting stands.
Would have been easier to swap in later model Dana 30 outers. Important: It's the back port of the master cylinder that is for the front brakes. The residual pressure valve is removed. |
#4 |
anyone have links to a write up? what about the 44?
#5 |
ooooops, port for the front....... that could have been bad.........
#6 |
Here is a link to the Chevy brake swap , it works . Write up is about a dana 25 , but it works for thw Dana 30 also.
Early CJ Disk Brake Swap Earlycj5.com |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
