brake fluid - JeepForum.com
post #1 of 11 Old 02-12-2008, 03:11 PM Thread Starter
drunkenrich
1980 CJ7
brake fluid
what kind of brake fluid should i use on my stock 1980 cj 7? dot 3? 4?
Also, do i have power brakes on this? or the other kind? it's stock. thanks guys
drunkenrich is offline
post #2 of 11 Old 02-12-2008, 03:17 PM
jatepper
Well, likely you do not have PB. To tell if you have PB, look for a booster diaphram behind the master cylinder in the engine compartment and it would have a vacuum line to the manifold. Also, the lid for the MC should tell you what type to use, but I think it is DOT 3.
Good luck.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #3 of 11 Old 02-12-2008, 03:25 PM
luckycheesehead
Should be DOT 3...
Stock could have had power or manual brakes. Do you have a brake booster on your firewall behind the Master Cylinder?
luckycheesehead is offline
post #4 of 11 Old 02-12-2008, 03:51 PM Thread Starter
drunkenrich
1980 CJ7
what does the brake booster look like? big round thing?
post #5 of 11 Old 02-12-2008, 03:52 PM
JFM626
JFM626's Avatar
you probably have Dot 3, however you may also have Dot 4. Dot 4 is compatible with Dot 3 it just has a higher boiling point. Do not use Dot 5 which is silicone based and not compatible with the glycol based fluids.
JFM626 is offline
post #6 of 11 Old 02-12-2008, 08:12 PM
HighCountry
I have only purchased DOT 4 for that last 15 years. It has a slightly higher boiling point which is needed if you go to Altitudes and as a bonus it does not absorb water vapor as quickly as the DOT 3. There is not downside to going with the 4 and a couple of ups, so why not.
Bruce
HighCountry is offline
post #7 of 11 Old 02-12-2008, 10:11 PM
John N
1981 CJ8
DOT 3 is will work fine. DOT 4 will do well as said above, plus it won't remove paint when it spills or leaks.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #8 of 11 Old 02-12-2008, 10:41 PM
JFM626
JFM626's Avatar
[QUOTE= DOT 4 will do well as said above, plus it won't remove paint when it spills or leaks.[/QUOTE]
Are you sure about that?
JFM626 is offline
post #9 of 11 Old 02-13-2008, 10:06 AM
John N
1981 CJ8
I haven't tried it myself, but have been told it more than once by good sources. Anyone on here know first hand?
John N
John N is offline
post #10 of 11 Old 02-14-2008, 09:58 PM
dimichele
It cost 3x as much.
dimichele is offline
post #11 of 11 Old 02-14-2008, 10:35 PM
Fjguercio
1978 CJ7
This is a picture of power brakes
Regards,
Fred
Fjguercio is offline
emergeny brake foot pedal removal and brake fluid removal???? sail78385 Jeep CJ Forum 1 04-03-2009 06:20 PM
Brake Fluid & ATF Fluid Questions avking Jeep CJ Forum 1 04-03-2009 11:55 AM
Brake fluid Dot 3 or 4? jeepjamboree Jeep CJ Forum 3 07-09-2008 02:41 PM
brake fluid or gear oil in brake drum tr6 Jeep CJ Forum 8 09-20-2005 06:27 PM
DOT 5 Brake Fluid JERSEYJOE Jeep CJ Forum 3 08-11-2004 06:53 AM
