Brake Experts! Need some input... - JeepForum.com
post #1 of 12 Old 09-03-2012, 06:09 PM Thread Starter
Manhattan
1981 CJ8
The CJ's just not stopping.
Here's the stuff...
- New booster and MC
- New lines
- New wheel cylinders, shoes and pads
Here's what's been done...
- Brakes have been power/vacuum bled 3x (using the high-temp fluid)
- Exhaust has been wrapped, heat shield built
(original thought was heat from exhaust)
Here's what it's doing...
- Right after bleeding, pedal feels good... then deteriorates - feels mushy (no leaks, puddles, etc)
- Left rear appears to be only wheel stopping - if I really stand on it, that tire will skid a bit.
- Left rear was smoking after I failed to stop at a stop sign (neighborhood), rolled through... Then stopped. No skid that time, but when I got out and looked, smoke was coming from the left rear brake drum.
- First thing in am (cold), drove 50', stood on brakes... Left rear skidded slightly... Jeep sloooooowed to a stop
Any idea? Bad prop valve?
Manhattan is offline
post #2 of 12 Old 09-03-2012, 07:34 PM
daltonw
1981 CJ7
are your front brake calipers installed on the right side. i had my calipers backwards one time and pumped brakes for a day and a half before i figured it out. its worth checking.
1981 CJ7 renegade, 1981 scrambler, 1986 CJ7 laredo
daltonw is offline
post #3 of 12 Old 09-03-2012, 07:41 PM
Mickey_Mouse
2013 KK Liberty
Mickey_Mouse is offline
post #4 of 12 Old 09-03-2012, 11:20 PM
BagusJeep
1981 CJ7
Sounds like a number of issues.
Have you checked the lines, Combination Valve, calipers and drums are assembled correctly?
Hace you adjusted the rear drums correctly?
When you bled the system did you hold back the Combination Valve? There is a pin on on eend you can hold in to deactivate the shut off valve when bleeding. Failure to do swill engage the valve, hence you will have only some brakes working.
If you pump the brakes rapidly does it brake better?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 12 Old 09-03-2012, 11:52 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
Originally Posted by Mickey_Mouse View Post
I know on a 84 there are two proportioning valves/combination valve. one under the drivers side on the frame, and one on the passenger side axle near the right tire. dont know if it really makes a difference, did you bench bleed the mc before installing it on the booster? have you adjusted the brakes drum brakes after you installed them (new springs and such as well).
thats not 2 prop valves, the one on the axle is just a splitter.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #6 of 12 Old 09-04-2012, 03:20 AM
cjjon7
1983 CJ7
Was there some shi* possibly on the drums when you put them on...grease oil etc? Always wipe new ones down with brake clean before using
cjjon7 is offline
post #7 of 12 Old 09-04-2012, 05:17 AM
CJunk
Check to see if your ebrake cables are sticking (or maybe just one). Also, you may have something sticking in the the rear brake hardware.
CJunk is offline
post #8 of 12 Old 09-05-2012, 10:58 AM Thread Starter
Manhattan
1981 CJ8
Thanks guys. The calipers are oriented correctly. The MC was bench bled. There aren't any leaks - MC is still topped off. Very frustrating.
Threw in the towel - and sent it to the pros. While this was a painful sight:
It was much less painful than stuffing the CJ into a tree with 150 miles on the odo... ;-)
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
post #9 of 12 Old 09-05-2012, 01:03 PM
cjjon7
1983 CJ7
May I ask what seats you have in there? I've always liked those.
cjjon7 is offline
post #10 of 12 Old 09-05-2012, 02:10 PM
85LaredoCJ7
I just had mine completely redone and had similiar issues prior to. It ended up being a bad MC.
The Dude abides....
85LaredoCJ7 is offline
post #11 of 12 Old 09-10-2012, 05:29 PM
tevans59
1979 CJ7
Wa gonna say maybe the adjustment rod between the MC and booster may needed to be adjusted as I had to do when I went from manual to a YJ booster and MC, Oh well sometimes we have to pay out when its whips our butt
tevans59 is offline
post #12 of 12 Old 09-10-2012, 10:05 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I agree w/what 85LaredoCJ7 said. My NEW M/C was bad. Maybe it sat in a warehouse forever. But when bleeding, it would just trickle out. I thought it was me not opening the bleeder up enough. Then I opened it all the way...same deal.
Not having brakes never stopped me before!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
Want your input on redoing the brake system on my CJ7 jpre32 Jeep CJ Forum 11 01-27-2012 10:30 AM
Any GM 4.3L experts out there? SlikRic Jeep CJ Forum 6 02-02-2011 02:50 PM
Brake line idea....input please neatocj Jeep CJ Forum 4 10-13-2008 09:25 PM
Calling All Brake Experts!! barry1me Jeep CJ Forum 11 05-27-2006 10:57 AM
All Experts I need... LakeOmen Jeep CJ Forum 2 11-01-2004 08:08 PM
