brake conversion? - JeepForum.com
post #1 of 5 Old 03-10-2007, 06:22 PM Thread Starter
mcktiger
brake conversion?
HEY GUYS,
I did a brake con. on my 74 cj5 disc up front new everything.Then did the yj swap booster, m/c, portioning valve .extend brake rod. Now my problem is that the rear brakes are locking up first .Oh ever thing in the rear is also new. Just a tad bit of drag on the rear wheels(not much). I see the comment of a residual valve in the m/c . whats that mean ? no air in system.
mcktiger is offline
post #2 of 5 Old 03-10-2007, 06:37 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A residual valve just keeps a preloaded amount of pressure on the rear drum brakes to counteract the brake return springs in the drum system. On a disk system, the pads free-float so a residual valve isn't usually needed. You might need to install an aftermarket adjustable proportioning valve. They cost about $40 or so and allow you to decrease the amount of pressure to the rear brakes to fine tune the system. I think they allow you to reduce pressure by about 30% or so.. IIRC.
BESRK is offline
post #3 of 5 Old 03-10-2007, 06:40 PM Thread Starter
mcktiger
thanks where to buy ?
mcktiger is offline
post #4 of 5 Old 03-10-2007, 07:30 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Summit racing, but have you adjusted the drums first?
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #5 of 5 Old 03-11-2007, 08:32 AM
gumby
gumby's Avatar
yj master cyl has that valve built in to it.
1984 CJ-7 offroad special loves to get dirty and play rough. unlike the girls I meet
258 rebuilt with torquer cam/ weber 32/36 carb, HEI ignition ,headers 4 in lift AMC 20 detroit rear locked and trussed / tru trax front 4:56 Gears ,solid axles on 35's
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference."-
Robert Frost
gumby is offline
CJ5 Brake conversion JFCIII Jeep CJ Forum 1 04-05-2009 08:16 PM
brake conversion snoogans Jeep CJ Forum 21 06-23-2008 09:34 AM
Brake conversion s.wetherald Jeep CJ Forum 5 03-25-2007 03:07 PM
yj brake conversion gumby Jeep CJ Forum 9 12-12-2006 10:18 AM
Brake Conversion tkempf Jeep CJ Forum 4 12-19-2002 04:00 PM
