Brake Combination Valve/Proportioning Valve Question - JeepForum.com
post #1 of 2 Old 12-18-2009, 10:20 PM Thread Starter
Wrangler1642
1979 CJ7
Hello,
first time posting so bear with me....
Question is for an 84' Jeep Scrambler. front disc and rear drums.
I have a question regarding the brake combination/proportioning valve.
First off is the entire unit called the combination valve and only a section of it the proportioning valve? From what I know only the rear drums are connected to the proportioning valve; is that correct?
Is what I labeled as the proportioning valve in the picture correct or is it internal?
Here is a link to the pictures if the photos dont work
Flickr: Wrangler1642's Photostream
Second off when I removed the entire unit and was cleaning it up, I noticed on the section that the rear brake line connects to HAD a small little rubber seal and washer that held it in place on the bottom of what I believe to be the proportioning valve.
The retaining washer and seal fell apart while I was cleaning the unit. If I had known better I would have avoided brushing that area but too late now.
So at the moment the seal and washer are missing but the entire unit seems fine except for this little exposed hole where the seal was.
Am I still able to use the valve even if this seal is missing or do I have to get a new unit?
Any ideas?
79' CJ-7 - 304, T18, Dana 300, 4in lift, 31" Muds
84' CJ-8 - 258, Chrysler 999, Dana 300, 4in lift, 33" Muds
Wrangler1642 is offline
post #2 of 2 Old 01-17-2011, 05:43 PM
jpywell52
1979 CJ7
the whole thing you have there is the proportioning valve. not sure how important that little piece of rubber is, probably just keeps dirt away from that hole but nothing should entering or leaving through that hole while your driving...
i just pulled the valve off mine in preparation for replacing all the steel lines. I'm hoping i can re-use my prpotioning valve as they are kind of expensive and not available locally.
jpywell52 is offline
brake warning switch on proportioning/combination valve whittlecj Jeep CJ Forum 1 10-24-2009 08:29 AM
brake proportioning valve jcooley7 Jeep CJ Forum 2 09-03-2009 06:01 PM
CJ Brake Proportioning Valve Question Shameless Elmer Jeep CJ Forum 6 01-12-2007 05:36 PM
brake proportioning valve gumby Jeep CJ Forum 6 12-30-2006 11:16 AM
brake proportioning valve certifiablejeep Jeep CJ Forum 3 07-16-2003 10:08 PM
