Which brake booster to use? - JeepForum.com
post #1 of 3 Old 09-15-2009, 01:55 PM Thread Starter
captdan
1982 CJ7
HI, I'm pretty new to the site and from what I've seen I love it already! I just picked up a 1982 Cj8 to add to my collection. I'm doing a full resto on it and was looking at the brakes today. I have no-power brakes and want to change them out to power brakes. I have seen adds in JP mag. for power boosters from other vehicle that fit in jeeps to help stop them better. Have any of you done this? Or should I just go with a stock power booster out of Cj? Any help would be great. thanks Dan
captdan is offline
post #2 of 3 Old 09-15-2009, 02:06 PM
only in a jeep cj
If your running 32 inch tires or under, I would stay with the stock power unit. You will need the firewall bracket, the booster and master all together.
Folks are always trying to swap in the YJ booster, but forget that the throw of the pushrod is different and the pedal pivot point is moved....IF mix matched, this results in low pedal or soft brakes. If you swap, swap all of it.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 3 Old 09-15-2009, 02:28 PM
78treehugger
1980 CJ7
I have a YJ setup in my CJ 7 and like it. I bolted it up without lengthening the rod and the pedal is very soft. They work very well but very soft. I will lengthen the rod at a later date. Easy swap. Very good upgrade. I am running 35's and I can lock up my tires on dry pavement.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
Brake Booster daadawg Jeep CJ Forum 4 11-28-2008 09:02 AM
Brake booster oh2winlemans Jeep CJ Forum 13 07-03-2008 10:04 PM
Brake Booster ckritcoad Jeep CJ Forum 28 12-24-2007 12:41 PM
brake booster? mcktiger Jeep CJ Forum 5 07-18-2006 03:36 PM
yj brake booster on a manual drum brake cj5? 77 renegade Jeep CJ Forum 2 02-12-2005 06:17 PM
