#1 | |
Brake Booster
I put a Brake Booster on my 1986 CJ-7. All the hard lines were changed and a full system bleed. The only item that wasn't changed was the porportioning valve. Should this be changed??? Is there a difference between the one used on a system with a brake booster and one without? I don't seem to be getting the braking that I thought I would the upgrade.
Daadawg/USMC |
#2 |
When I swapped over to power brakes, I had to fab up an adjustable brake rod. When you swapped in the booster, did you get a new brake rod(Pedal to booster) with it? Or are you using your old one off the manual brakes?
One I put a longer rod on, my brakes worked much better.
Keep Public Lands Open to all the Public. GLFWDA Land Use Committee Member |
#3 |
Parts Locator
If you upgraded to a CJ power brke system you won't see much of a difference. The proportioning valve is the same for power and non-power brakes.
Did you switch to a power brake master cylinder? -
84 CJ7 Northstar V8 Pictures of it, http://s56.photobucket.com/albums/g198/cjinpa/odds%20n%20ends/?start=all 91 YJ Renegade, Daily Driver since 1991. 97 TJ daily driver. 2011 F250 King Ranch. Jeeps that I am currently parting out; 91 YJ Renegade 5spd 1990 YJ auto 1991 YJ 4cyl 5 spd Just my luck I was born in the land of plenty now there ain't enough. |
#4 | |
I am going to have to respectfully disagree with you on that. I went from standing on the brake pedal to 1/3 pedal darn nears locks up all 4 brakes. I put the CJ booster and M/C on mine and made the longer brake rod for it. Not much difference prior to the new brake rod though.
#5 | |
The CJ power brakes are much better then the CJ non-powered brakes, but overall still suck compared to comparable units. My old CJ had non-power brakes and I did the YJ swap and the first time I hit the brakes on the neighborhood test drive my head almost hit the windshield. Sold that CJ and the new CJ I have came with factory PB and have nowhere near the stopping power as the YJ PB's had.
1985 Jeep CJ-7 Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage. USMC 1999-2004 Semper Fi! Torchmate CNC Plasma Table Build / Projects |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
