brake booster - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > brake booster
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome Open box items at OPENBOXOFFROAD.COMJeep parts, deals and more at JeepHut.com
Unread 12-20-2014, 07:07 AM   #1
milemaker01
brake booster
Just wondering ....I have an 81 cj7 and am replacing the tub with a 95 yj steel tub. My question is by putting in a ma *** tee cylinder with the vacuum boost would be possible and would it give me power brakes
Sent from my SPH-L710 using JeepForum
milemaker01 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2014, 07:29 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The forum didn't like your spelling... Lol. Yes you can convert to power brakes. Just be aware you will need the offset air filter assembly that sits on the valve cover for clearance. The one that sits on the carb will hit the master when you are on the throttle hard.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 12-20-2014, 07:45 AM   #3
milemaker01
Thanks for the info Mike I did not know that.I appreciate the input and thanks
Unread 12-20-2014, 08:14 AM   #4
RedNeckCorvette
1979 CJ7
I was wondering what was going on there with that ****.
RN
RedNeckCorvette is offline   Reply With Quote Quick reply to this message
