boxed frame idea... - JeepForum.com
post #1 of 7 Old 09-12-2009, 12:13 PM Thread Starter
paraman72
boxed frame idea...
Since most of the boxed frames rust from the inside out, I was thinking of a way to clean the rust and prevent the cancer. Since I had to cut off the rear crossmember I purchase a cheap chimney sweep on stealbay that I am going to trim down and run it through the frame. Then por-15 it of using the marine clean and metal ready. Whacha think about those apples.
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline
post #2 of 7 Old 09-12-2009, 04:16 PM
CJman77
1977 CJ7
Yeah I did the same thing basically. But I took a sponge and tied a really long rope to it ( in the middle) and then pulled it through rear to front and back again out the rear.
But who knows how much crap I just painted over. I know the insides of my frame were bad news. I stood it up and all kinds of small rust chunks would come out. And I sand pressure washed it out. And then let it dry and phospo etched it. then did the paint trick. Cost me less then 100 bucks as opposed to the 500 I was looking at the galvanize. Although I wish it were galvanized but it is what it is.
Hopefully I have welded it back together with enough metal!
CJman77 is offline
post #3 of 7 Old 09-12-2009, 05:07 PM
jsc7002
1966 CJ5
I thought about doing that but the frame I have is in pretty good condition and I didnt see any spots that looked like they might be weak or thin, besides when this frame starts rusting out, I will make my own frame thta is stronger and cleaner
jsc7002 is offline
post #4 of 7 Old 09-14-2009, 08:50 AM Thread Starter
paraman72
well hopefully by doing this the frame will outlast me...
post #5 of 7 Old 09-14-2009, 12:34 PM
rixcj
rixcj's Avatar
1979 CJ5
If the brush has steel bristles, don't do it. I had the same idea.
I bought a 5" square steel bristle chimney brush, then trimmed it down, with a cutting wheel.
I trimmed, then tried it, trimmed some more, tried it, etc. When I thought I had it trimmed enough, I shoved it in the rear opening of the frame...about 4" in.
It was nearly impossible to get out!! The bristles will face the direction of the push, when entering, but do not want to reverse themselves, when you go to pull the brush back out!
Of course, I finally got it, but it was a hassle.
I ended up buying a 7pc. engine cleaning brush kit, with abrasive, nylon bristles, and shoved them into frame holes. I did the best that I could, then blew the frame out with air. Good enough.
I'm going to spray boiled linseed oil in there, and call it a day.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #6 of 7 Old 09-14-2009, 02:24 PM Thread Starter
paraman72
would be funny driving around with a chimney brush hanging out the *** end of my frame....
post #7 of 7 Old 09-14-2009, 02:36 PM
datmony
Boiled linseed is a great option. That is what anyone who has steel bicycles uses to keep the in good shape. Been being done since before the turn of the century and that stuff lasts forever and a day. Good call rixcj.
datmony is offline
back half of cj5 frame to replace rotted cj7 frame? jedsled Jeep CJ Forum 8 05-30-2011 05:11 AM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 08:44 PM
CJ-5 and its non-boxed in frame...solution?? think369 Jeep CJ Forum 10 09-09-2009 10:01 PM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 10:44 PM
Boxed frame BIGJMCCONNELL Jeep CJ Forum 4 04-04-2003 06:55 AM
