Bought a coolant overflow bottle, Where the heck does it mount - JeepForum.com
post #1 of 17 Old 05-07-2012, 06:40 PM Thread Starter
jshi218
I bought a coolant overflow bottle for my 86 CJ. I figured that there would be some mounting holes and I could figure out where it went. Well no luck there. Anybody got pictures.
jshi218 is offline
post #2 of 17 Old 05-07-2012, 06:42 PM
KJNewbs
1983 CJ7
No pics at the moment, but it should instal on the driver side fender above your charcoal canister. I believe it mounts via 3 holes and shares one with the washer fluid bottle (if you have one).
-KJ Newbs / Jersey
1983 lime green CJ7 - 258 with DUI & Weber, Crane cam, 2" lift, MTs w/ BFGs
2010 2-Door, 6-Speed Black JK Sahara - Teraflex 3" Coil Lift with Front Lower and Rear Upper Flex Arms - Bilstein 5100 Shocks -JKS Front Adjustable Track Bar - Teraflex Front Knuckle Gussets - Rock Hard Oil Pan/Engine Skid - Rock Hard Transfer case skid - Rock Hard Evap relocation Kit - Poison Spyder Rocker Knockers - MBRP off-road exhaust - AEV Pintler Wheels - GoodYear MTR/K 35x12.5x17 - Detroit Track Loc Carrier up Front - Yukon 4.88 Gears - Cobra 75 CB with Cool Tech bracket - Die-Tech mirror relocation brackets
KJNewbs is offline
post #3 of 17 Old 05-07-2012, 06:51 PM
gmgreen
1983 CJ7
This.
gmgreen is offline
post #4 of 17 Old 05-07-2012, 06:52 PM
mopar346
You can see it in this one in front of the master cylinder, it's an 84.
Careful your character's showing
mopar346 is offline
post #5 of 17 Old 05-07-2012, 06:54 PM
keith460
Jeep. There's Only One
keith460's Avatar
Right about there next to the washer fluid tank.
1984 CJ-7 Renegade
keith460 is online now
post #6 of 17 Old 05-07-2012, 06:56 PM
mopar346
After looking at Keith's I'm thinking mine aint factory.
mopar346 is offline
post #7 of 17 Old 05-07-2012, 06:58 PM
mopar408
1974 CJ5
looks like on the top of the passenger side by the fan shroud:
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #8 of 17 Old 05-07-2012, 07:02 PM
mopar346
Seen that a time or two, that is the executive model with a bottom sump.
mopar346 is offline
post #9 of 17 Old 05-07-2012, 07:13 PM Thread Starter
jshi218
Thanks guys. No wonder why I couldn't find mounting holes right by the radiator
jshi218 is offline
post #10 of 17 Old 05-07-2012, 07:48 PM
keith460
keith460's Avatar
Nope, can't say that it is.
The one I showed is from the factory equipped CJ's with heavy duty cooling that have the radiator cap more towards the drivers side. CJ's equipped with the standard 2 core radiator and a fixed cooling fan, like mine, did not have a coolant overflow tank. Just a hose coming off the center mounted radiator cap and draining to the ground on the passenger side.
1984 CJ-7 Renegade
post #11 of 17 Old 05-07-2012, 08:11 PM
Trapshooter
I wish my engine compartment looked that clean
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #12 of 17 Old 05-07-2012, 08:33 PM
BagusJeep
1981 CJ7
There are several different arrangements according to year and engine and whatever was added to your CJ by the PO. "Coolant recovery" was only fitted with the Heavy Duty and factory air conditioning packages and you would have had an extra 2.8litres of coolant.
It should be affixed to the fender near the radiator on the driver's side facing across the engine bay. It has two lugs (maybe at the top) which are bolted through the fender. (I hope this makes sense).
I attach several cuts from the FSM and the parts manual. They all show completely different tanks, so take your pick. However they indicate the same general mounting position.
Mine have relatively small condenser tanks which are mounted next to the radiator. There is a bracket and the tank slides over the bracket on a 1984 258ci and 1981 258ci, both were HD cooling from the assembly plant in Jakarta but who knows what they were thinking when they assembled them from kits. It doesn't really matter where you put it as the radiator will suck it back up the hose and you would need a difference in height of about 25 feet to prevent it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #13 of 17 Old 06-25-2013, 07:28 PM
CJ7ROB
Anyone know best place, best deal to get new overflow bottle and washer bottle? thanks
CJ7ROB is offline
post #14 of 17 Old 06-26-2013, 04:37 AM
keith460
keith460's Avatar
I have a spare OEM 'used' overflow bottle that I can sell and ship. PM me if you are interested.
1984 CJ-7 Renegade
post #15 of 17 Old 06-26-2013, 10:45 AM
holliewood61
1981 CJ7
I have a couple washer jugs I could ship one as well
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
1983 CJ7 coolant overflow/recovery bottle cjkcj7 Jeep CJ Forum 16 12-24-2014 06:15 AM
CJ Coolant Overflow Bottle - repair or replace? N7TX Jeep CJ Forum 6 09-07-2011 06:01 PM
Overflow bottle and washer fluid bottle? spottedfrog Jeep CJ Forum 8 08-21-2011 04:04 PM
Stock locations of washer bottle and overflow bottle? cw4stein Jeep CJ Forum 3 12-23-2009 08:46 PM
overflow bottle CJMONEYPIT Jeep CJ Forum 5 01-10-2003 06:38 PM
