-   -   Bought a coolant overflow bottle, Where the heck does it mount (http://www.jeepforum.com/forum/f8/bought-coolant-overflow-bottle-where-heck-does-mount-1366203/)
jshi218 05-07-2012 06:40 PM
I bought a coolant overflow bottle for my 86 CJ. I figured that there would be some mounting holes and I could figure out where it went. Well no luck there. Anybody got pictures.
KJNewbs 05-07-2012 06:42 PM
No pics at the moment, but it should instal on the driver side fender above your charcoal canister. I believe it mounts via 3 holes and shares one with the washer fluid bottle (if you have one).
gmgreen 05-07-2012 06:51 PM
This.
mopar346 05-07-2012 06:52 PM
1 Attachment(s)
You can see it in this one in front of the master cylinder, it's an 84.
keith460 05-07-2012 06:54 PM
Right about there next to the washer fluid tank.
http://i123.photobucket.com/albums/o...JDetails44.jpg
mopar346 05-07-2012 06:56 PM
After looking at Keith's I'm thinking mine aint factory.:(
mopar408 05-07-2012 06:58 PM
looks like on the top of the passenger side by the fan shroud:
http://i37.tinypic.com/1zz6vyd.jpg
mopar346 05-07-2012 07:02 PM
Seen that a time or two, that is the executive model with a bottom sump.
jshi218 05-07-2012 07:13 PM
Thanks guys. No wonder why I couldn't find mounting holes right by the radiator
keith460 05-07-2012 07:48 PM
Nope, can't say that it is.
The one I showed is from the factory equipped CJ's with heavy duty cooling that have the radiator cap more towards the drivers side. CJ's equipped with the standard 2 core radiator and a fixed cooling fan, like mine, did not have a coolant overflow tank. Just a hose coming off the center mounted radiator cap and draining to the ground on the passenger side.
Trapshooter 05-07-2012 08:11 PM
I wish my engine compartment looked that clean :thumbsup:
BagusJeep 05-07-2012 08:33 PM
3 Attachment(s)
There are several different arrangements according to year and engine and whatever was added to your CJ by the PO. "Coolant recovery" was only fitted with the Heavy Duty and factory air conditioning packages and you would have had an extra 2.8litres of coolant.
It should be affixed to the fender near the radiator on the driver's side facing across the engine bay. It has two lugs (maybe at the top) which are bolted through the fender. (I hope this makes sense).
I attach several cuts from the FSM and the parts manual. They all show completely different tanks, so take your pick. However they indicate the same general mounting position.
Mine have relatively small condenser tanks which are mounted next to the radiator. There is a bracket and the tank slides over the bracket on a 1984 258ci and 1981 258ci, both were HD cooling from the assembly plant in Jakarta but who knows what they were thinking when they assembled them from kits. It doesn't really matter where you put it as the radiator will suck it back up the hose and you would need a difference in height of about 25 feet to prevent it.
CJ7ROB 06-25-2013 07:28 PM
Anyone know best place, best deal to get new overflow bottle and washer bottle? thanks
keith460 06-26-2013 04:37 AM
I have a spare OEM 'used' overflow bottle that I can sell and ship. PM me if you are interested.
holliewood61 06-26-2013 10:45 AM
4 Attachment(s)
I have a couple washer jugs I could ship one as well
The time now is 02:07 AM.
