Bought a CJ! - Page 8 - JeepForum.com
post #106 of 136 Old 04-14-2013, 08:00 PM
contdevelop
Good luck with the axles. Did you check the AMC 20 to see what happened. You probably just spun a hub.
contdevelop is offline
post #107 of 136 Old 04-14-2013, 08:09 PM Thread Starter
dmoffat
1977 CJ7
Thanks. You may very will be right about the hub. I haven't bothered to dig into it because I was planning on doing this swap eventually anyway. This is just a good excuse to do it sooner.
1977 CJ7 -- 304, SM465, Dana 20, custom front radius arm, Dana 44/14 bolt with 4.56 gears, 39.5x13.50-17 Iroks,
Build thread-
98 Wrangler - 2.5L, 5spd, 4" Rough Country lift, Homemade Highline, 35" Buckshot Mudders - SOLD
dmoffat is offline
post #108 of 136 Old 04-17-2013, 05:59 PM Thread Starter
dmoffat
1977 CJ7
I did bring some tires back from Denver... got my spool installed and rear diff set back up. Also checked out my radius arm builders parts that came in. Looks like its all there. Still waiting for my steering kit and rear disc conversion bracket. Hopefully they'll be here tomorrow and I'll have a really busy weekend.
ForumRunner_20130417_175911.jpg   ForumRunner_20130417_175924.jpg   ForumRunner_20130417_175942.jpg
Build thread-
dmoffat is offline
post #109 of 136 Old 04-18-2013, 09:16 PM Thread Starter
dmoffat
1977 CJ7
After doing some reading and research I've kind of backed off the air shock idea. I would love to drop the cash on ORI air struts but I'm already stretching my budget. Now I'm thinking coilovers. I am leaning towards a set of King 2.0 Emulsion coilovers... Am I an idiot?
Build thread-
dmoffat is offline
post #110 of 136 Old 04-20-2013, 12:40 AM Thread Starter
dmoffat
1977 CJ7
Here's some picks. Brake lines are only temporarily ran, u-bolts are way too long, cut some tube for spacers also TEMPORARY... so yeah, I'm tired and don't have a whole lot else to say right now. Not real happy about how tall it appears its going to be. But tomorrow is a new day...
ForumRunner_20130420_003756.jpg   ForumRunner_20130420_003820.jpg   ForumRunner_20130420_003835.jpg   ForumRunner_20130420_003851.jpg   ForumRunner_20130420_003910.jpg
Build thread-
dmoffat is offline
post #111 of 136 Old 04-20-2013, 12:43 AM Thread Starter
dmoffat
1977 CJ7
Couple more pics. Last is relatively close to ride height.
ForumRunner_20130420_004254.jpg   ForumRunner_20130420_004307.jpg   ForumRunner_20130420_004319.jpg
Build thread-
dmoffat is offline
post #112 of 136 Old 04-20-2013, 07:56 PM Thread Starter
dmoffat
1977 CJ7
Progress!! Amazing how a bit of sleep and stepping back improves my motivation. Things are coming together. Did have to order a different upper coilover mounting system. Everything is tacked together right now but it looks like its gonna work.
ForumRunner_20130420_195503.jpg   ForumRunner_20130420_195544.jpg   ForumRunner_20130420_195600.jpg   ForumRunner_20130420_195617.jpg   ForumRunner_20130420_195625.jpg
Build thread-
dmoffat is offline
post #113 of 136 Old 04-21-2013, 12:31 AM Thread Starter
dmoffat
1977 CJ7
Finished welding and threw some paint on things. Gonna reassemble the control arms and such tomorrow and build crossover steering. Should be able to drive it out with the 2x2 keeping the front solid at ride height.
ForumRunner_20130421_002837.jpg   ForumRunner_20130421_002845.jpg   ForumRunner_20130421_002905.jpg   ForumRunner_20130421_002918.jpg
Build thread-
dmoffat is offline
post #114 of 136 Old 04-21-2013, 04:25 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
I don't know how I have missed this thread.
I think you should look I to a front three link, or four link. A front radius arm suspension will twist the axle tubes, or destroy your joints.
Also, your track bar and drag link MUST be the same length, and run parallel to each other. Otherwise you will have bump steer.
Great job so far!
Mail crawling.
MisfitSeven is offline
post #115 of 136 Old 04-21-2013, 09:21 AM Thread Starter
dmoffat
1977 CJ7
Great job so far!
You are very right, I never thought about how it would try to twist when articulating. It's so obvious now. I think I'll try to get by for a little while and then convert it to a 3-link. Thanks for bringing it to my attention. As for steering I should be dead on.
Just where is Bennington? East side I'm sure.
edit... Now I'm really curious if a guy could get away with only running one of the upper links on the radius arm. That would take the bind out and stress off the brackets. Anyone have any thoughts on that??
Build thread-
dmoffat is offline
post #116 of 136 Old 04-21-2013, 10:26 AM
MisfitSeven
MAiL Crawler.
Bennington is almost a suburb of Omaha. It's right next to it. 156th street and Hwy 36.
There have been good reports on only having a three link radius setup. I was toying with the idea of building a similar setup on my TJ with a removable fourth radius link for off road use, keeping it for on road.
Mail crawling.
post #117 of 136 Old 04-21-2013, 12:27 PM Thread Starter
dmoffat
1977 CJ7
Crazy that we may be in the same state but but be hundreds of miles apart.
I think I may try doing just what you're thinking. Leave both uppers in on the road (what little of it the jeep will see) and try taking one out on the trails.
I've set myself a pretty short deadline, a buddy and I have a Black Hills trip planned in just 3 weeks. I shall see how it works.
I did get my steering together. The keen eyed viewer may notice the grade 5 bolts, they are just for mock up, I'll have to pick up some grade 8's this week. Also my drag link is about 2 inches shorter than the panhard bar so it is close, but far from perfect. Pretty much out of jeep parts for the weekend so outside it goes.
ForumRunner_20130421_122547.jpg   ForumRunner_20130421_122602.jpg   ForumRunner_20130421_122614.jpg
Build thread-
dmoffat is offline
post #118 of 136 Old 04-25-2013, 08:23 PM Thread Starter
dmoffat
1977 CJ7
Couldn't help myself, mounted up my tires. Also go the right u-bolts installed for the rear. That's about it. Like I've said, the front will definitely come down 2-3 inches. I though about losing the spare tire carrier, but I think the extra weight on the rear could bring it down an inch or so which would be good in my opinion. Just wish my coilovers would show up already.
32378_10200531887755064_2046691137_n.jpg   400713_10200531889755114_394315464_n.jpg   933897_10200531890835141_1661336924_n.jpg
Build thread-
dmoffat is offline
post #119 of 136 Old 05-12-2013, 09:54 PM Thread Starter
dmoffat
1977 CJ7
Deadline has come.. Still waiting for coilovers and upper mount kit. I did get some front brake lines installed (for a '75 GM with a 12" lift).. Trimmed the rear fenders a bit.. Bought a wheel and mounted up a spare and gave my driveshafts to the machinist to extend them both. I think that's all lately. Just waiting..
Build thread-
dmoffat is offline
post #120 of 136 Old 05-16-2013, 09:08 PM Thread Starter
dmoffat
1977 CJ7
Finally gots me some parts.. hopefully I'll get atleast one driveshaft tomorrow and get this thing almost wrapped up this weekend.
Build thread-
dmoffat is offline
14 bolt , dana 44 swap , radius arm
I just bought an 82 CJ 7 Bwanabill Jeep CJ Forum 74 10-23-2011 06:55 AM
Bought a 83 CJ7 sshafer03 Jeep CJ Forum 6 10-19-2010 09:48 AM
Just bought a '83 CJ 7 and need some help sgt jeep Jeep CJ Forum 5 04-07-2007 10:37 AM
Help - Just bought 86 Cj7 qwert98 Jeep CJ Forum 4 04-25-2006 10:22 AM
I just bought a CJ-5 (I think) Tyork_tex Jeep CJ Forum 22 04-21-2006 11:05 PM
