Bondo hell now what do I do?? - Page 2 - JeepForum.com
post #16 of 16 Old 10-20-2011, 12:26 PM
MONSooNmonkey
Originally Posted by gmakra View Post
Its not bad at all. You will need to do some hammer and dolly work quite possibly shrink the metal a bit too. Even if you had a perfect replacement panel you would still need to use body filler. Were body filler gets a bad rap is when some clown uses 50 LBS on a dent. The idea is to get the metal as straight as possible then use the filler as little as possible.
Exactly, ******* that fill in a 3\8ths dent with bondo instead of just tapping the steel as flush as possible THEN applying body filler.
Body work is easy peasy lemon squeezie as long as you have an oz of patience.
Sadface :(
MONSooNmonkey is offline
Rocker Guards and Bondo putty31 Jeep CJ Forum 7 10-21-2011 04:25 AM
what the hell is this part ?? stvincnt Jeep CJ Forum 18 08-13-2010 03:01 PM
Will U-Pol Raptor adhere to bondo?? xbarksdale Jeep CJ Forum 2 09-01-2009 06:27 AM
Why couldn't I bondo the entire undercarriage of my Jeep? part.changer Jeep CJ Forum 17 05-12-2007 06:43 PM
Bondo or not to Bondo bods7 Jeep CJ Forum 7 02-20-2005 08:54 AM
