Bondo hell now what do I do?? - JeepForum.com
post #1 of 16 Old 10-19-2011, 01:57 PM Thread Starter
nolefansjeep
2015 JK Wrangler
I took off the diamond plate off the new to me 77 CJ7 and then was sanding down the holes to weld them closed and ran in to tons of bondo. Now I see why the diamond plate was there. My question is is there replacement panels for this area that has Jeep stamped on it or do I have to just rummage through junk yards? I hate bondo with a passion especially since I am trying to restore this thing. What I thought was a steal of a deal is going south quick. Here is pics of what I found:
http://www.flickr.com/photos/nolefansjeep/6261676126/
Now keep in mind I don't have the money for a new steel tub either. I am lucky to get a $25 allowance on this baby a week and if I spend more mama ain't happy and if she ain't happy no one is happy.
nolefansjeep is offline
post #2 of 16 Old 10-19-2011, 02:21 PM
gmakra
Its not bad at all. You will need to do some hammer and dolly work quite possibly shrink the metal a bit too. Even if you had a perfect replacement panel you would still need to use body filler. Were body filler gets a bad rap is when some clown uses 50 LBS on a dent. The idea is to get the metal as straight as possible then use the filler as little as possible.
gmakra is offline
post #3 of 16 Old 10-19-2011, 02:30 PM
Jim1611
Jim1611's Avatar
You look to have a good Jeep logo so I'd try to keep that. The bondo may be filling dents and not hiding rust. You need to find this out. Really for the way you want the paint to last you need to take most of the factory paint off. That's the only way you're going to see what you really have. Also to put a good paint job over a sloppy one will net problems in the future. A fairly cheap way to remove the paint is to buy yourself a gallon of aircraft stripper. Be careful though, it really burns your skin!!
Here's a shot of it at work on my hood. I did some sandblasting to get to the hard to get at areas also. It takes several applications of the stripper so take your time
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #4 of 16 Old 10-19-2011, 02:47 PM Thread Starter
nolefansjeep
2015 JK Wrangler
Ok I posted a new picture as well I wanted to sand down to the metal to see what I was working with and there is a crack in the panel and about 1/2" of bondo over it. I know I will have to replace that panel I just haven't gotten to the rest yet to see how bad that is.
post #5 of 16 Old 10-19-2011, 02:51 PM
jaxfljeep
1980 CJ7
Nolefan: I bet the bondo isn't upsetting you nearly as much as knowing you bought an Orange and Blue Jeep. Sorry, I had to say it.
jaxfljeep is offline
post #6 of 16 Old 10-19-2011, 02:52 PM Thread Starter
nolefansjeep
2015 JK Wrangler
Hey Jim will that aircraft stripper remove the bondo as well or do I have to sand that away before I use it?
post #7 of 16 Old 10-19-2011, 03:01 PM
somdfisher
1981 CJ7
When I bought mine, I started sanding it down and went through about 2" of bondo before getting to where the po burned through the entire passenger side with a welder and I also found a 1/4" steel plate under it. I cut the whole side off and replaced it. I still have a little filler to use to smooth it out but I used bed line spray on the whole thing to hold me over until I get to a garage and redo that area.
Edit: forgot to mention that in the middle of summer, it looked like it snowed at my house there was so much dust.
O|||||O 1981 CJ7, 258, 4 speed..If it ain't cut, it ain't custom.
somdfisher is offline
post #8 of 16 Old 10-19-2011, 03:27 PM Thread Starter
nolefansjeep
2015 JK Wrangler
trust me as soon as I took off the diamond plate I was like oh $#@% my Florida fan friends are going to have a field day with me on this one. That is why I have to get this thing fixed and painted ASAP lol
I used to live in Jacksonville for 14 years just moved up here to the frigid north 5 years ago. I had a white 2005 Jeep Wrangler Rubicon Unlimited when I lived down there. Maybe you saw it running around Jax.
post #9 of 16 Old 10-19-2011, 03:38 PM
Jim1611
Jim1611's Avatar
Yes the stripper will loosen the bondo. I had some on one of my fenders and it took it off. Just apply the stripper as directed, it's important to only brush it one way, and let it work but don't let it dry. I used a puddy knife to scrape what what loose off. Apply another coat of stripper and do the same all over. It took me about 45 minutes to strip one fender but I was being careful and trying to be as neat as possible, the stripper is hard on anything it touches, washes off with water though.
The last pictures shows some good metal for you to work with. The hoes you have can be cut out and replaced with patches made from sheet metal. I used 16 gauge but 18 will work too. Do you have any welding experience? Are you planning to take the tub off? From what you say it sounds like you want to do a very good job that'll last. You could weld all of the body with a 120 volt welder if you know how. It would be more handy for you than taking it to a shop, which unless you have a friend that can do it, you'll spend a good bit of money.
Here's an example of fixing rust that I needed to do on my hood. None of that filler is over 1/16" thick. 1/8" is what many think is the max. Also I've done very little of this so that it's not as hard to do as we sometimes make it.
My build thread
Jim1611 is offline
post #10 of 16 Old 10-19-2011, 03:44 PM
Jeepican
1976 CJ5
just fyi .... "if" you do need the panel ... you can get it here .... http://www.classicent.com/jeep.php
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #11 of 16 Old 10-19-2011, 05:40 PM
brownbagg
1930 MK Compass
mine was like that too, common jeep problem. I took some steel diamond and welded it it, it will never rot and if I rub a tree it take the tree with it.
brownbagg is offline
post #12 of 16 Old 10-20-2011, 06:18 AM
yahwhy
1982 CJ7
have you pulled the d plate off the windshield frame yet,probally won't be pretty either.
yahwhy is offline
post #13 of 16 Old 10-20-2011, 07:40 AM Thread Starter
nolefansjeep
2015 JK Wrangler
not yet but it is in the plans
post #14 of 16 Old 10-20-2011, 08:08 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
There is absolutely nothing wrong with PROPERLY USED Bondo. There isn't a vehicle out there that has had body work done that doesn't have some on it.
The bad rep comes from people using it to fill big dents and holes. Not what it's for. It's for smoothing properly straightened panels out, and should never be more than 1/4" thick. Even thinner if you can help it. It'll outlast your vehicle and likely you if used correctly.
Sent from my DROID3 using JeepForum
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #15 of 16 Old 10-20-2011, 12:23 PM
weehce
1983 CJ7
I don' know much about that. What I do know is it doesn't like to be wheeled hard.
1983 CJ7, 1952 MCM38, 1952 MCM38
weehce is offline
Rocker Guards and Bondo putty31 Jeep CJ Forum 7 10-21-2011 04:25 AM
what the hell is this part ?? stvincnt Jeep CJ Forum 18 08-13-2010 03:01 PM
Will U-Pol Raptor adhere to bondo?? xbarksdale Jeep CJ Forum 2 09-01-2009 06:27 AM
Why couldn't I bondo the entire undercarriage of my Jeep? part.changer Jeep CJ Forum 17 05-12-2007 06:43 PM
Bondo or not to Bondo bods7 Jeep CJ Forum 7 02-20-2005 08:54 AM
