Bolting springs to shackles - JeepForum.com
post #1 of 3 Old 06-18-2003, 12:13 PM Thread Starter
bstruckm
bstruckm's Avatar
Ok, my 81 Cj7 project moves on, tonight weather permitting I should be able to bolt the axles back onto the frame
I bought all new grade 8 bolts, and heavy duty shackles.
My question is should I use a flat washer or a lock washer on the nut side, and should I use a flat washer on the bolt head side?
Any suggestions?
Thanks
bstruckm is offline
post #2 of 3 Old 06-18-2003, 12:17 PM
jadams68
jadams68's Avatar
When I put my RE lift on, it required no washers on either side.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 3 Old 06-18-2003, 12:44 PM
rustyCJ
for the spring main eye bolt you can use a lockwasher because of the sleeve in the bushing and the rigid hanger, the shackle bolts need to stay semi loose to allow flex. i always go buy new nylock nuts(or whatever they are called) cause they still lock even if not torqued down.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
4" BDS springs wont fit shackles thich Jeep CJ Forum 7 08-17-2009 10:28 AM
bolting up my 304 to my t18 help pcairns Jeep CJ Forum 9 06-30-2009 11:38 PM
Shackles, Shocks, and Springs tamu83cj Jeep CJ Forum 1 04-28-2005 11:21 PM
Shackles for Reversal w/ YJ Springs? MudLover Jeep CJ Forum 2 02-16-2005 10:48 AM
Shackles for military wrap springs Jeep Daddy Jeep CJ Forum 2 06-28-2002 12:49 AM
