Bolt torque setting on a few things... - JeepForum.com
post #1 of 6 Old 09-02-2012, 11:03 AM Thread Starter
drespecki
1983 CJ7
Looked through the FSM but cannot find a few torque settings I need...
Shock tower to frame bolts:
Engine mount bracket to frame bolts:
Thanks!
(1983 CJ7 258 auto)
It only hurts while you're breathing..
drespecki is offline
post #2 of 6 Old 09-02-2012, 12:14 PM
CSP
Those really aren't critical as they don't involve moving parts. Google any bolt torque reference chart which will give you torque values based on the bolt size/thread type.
Personally I would use the German Gudentight torque value on those.
CSP is offline
post #3 of 6 Old 09-02-2012, 01:03 PM Thread Starter
drespecki
1983 CJ7
I am using the OEM bolts again on these...were they grade 5 or 8? Maybe less?
I see the charts and I need the spec of the bolts..
I usually use goodntite but thought I might check first and see what the ft. lbs. is..
post #4 of 6 Old 09-02-2012, 01:33 PM
VACJ7
VACJ7's Avatar
The shock tower spec is not in the FSM as you discovered. Engine bracket to frame is in there but they call it the sill. They have a ridiculously high torque valve for those, but they are fine thread. I did CSPs method for both.
'84 CJ-7 |
VACJ7 is offline
post #5 of 6 Old 09-02-2012, 01:39 PM
Hashbrown
Blissfully Unaware
Hashbrown's Avatar
1980 CJ7
I usually just cross thread them.
Live Free And Don't Be A Dick
Hashbrown is offline
post #6 of 6 Old 09-05-2012, 10:27 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
2Xtreme is offline
Bolt Torque on WaterPump twoguns Jeep CJ Forum 3 12-22-2010 07:46 PM
Engine Mount Torque Setting? jpd1899 Jeep CJ Forum 1 10-31-2010 11:28 AM
manifold bolt torque? 82Renegade Jeep CJ Forum 4 04-24-2009 09:18 PM
Tie rod end torque setting and grease? DT5150 Jeep CJ Forum 3 03-20-2008 12:30 PM
Torque setting for body bushings BIGM Jeep CJ Forum 2 03-13-2006 06:05 AM
