Bolt size for tub on 85CJ - JeepForum.com
post #1 of 8 Old 09-09-2002, 11:21 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
One of my main bolts it missing from the frame to tub mount. What size bolts are the 6 bolts along the sides of the tub and frame. Those 6 seem to be all about the same.
I'd pull one of the existing bolts out, but they are rusted in there pretty good and I don't want to mess with it if I don't have to.
I just want to buy one new bolt, slap some anti-sieze on it and tighten it up.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 8 Old 09-10-2002, 06:36 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Never mind. I bought a 3/8 x 2" and it did the trick.
post #3 of 8 Old 09-12-2002, 06:50 PM
cjryder
Jeep Daddy, I just bought a set of hardware for my CJ that is all stainless from 4wdHW. It is pretty complete, and everything is separately packaged and labeled. If you ever get the itch to replace those rusty ones, might be worth looking at. The whole thing is under a c-note, but you need the body washers as well.
cjryder is offline
post #4 of 8 Old 09-12-2002, 11:15 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Actually I had to tighten up most of the bolts because they seem to be loose. They are a little rusty, but I am thinking of doing a 1" body lift. In that case I'll be replacing all the bolts anyway. I wonder if they include the 1" spacers and the rubber donut that go under the washers and bolt heads. I'm missing one of the rubber donuts.
post #5 of 8 Old 09-13-2002, 06:52 AM
cjryder
If you are lifting it anyway, you should consider polyurethane.
These kits include all bushings needed plus the washers and bolts. I just bought a 'total kit' which has body mounts, tie rod ends, and leaf spring bushings
cjryder is offline
post #6 of 8 Old 09-13-2002, 08:53 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
What did this kit cost and where did you get it. I need to replace my tie rod ends anyway. My leaf spring bushings are new though. Did you get 3 tie rod ends, or did you get all 4? even the pitman tie rod assembly?
post #7 of 8 Old 09-13-2002, 01:39 PM
cjryder
mine was only about 50 bucks from 4wd hardware, but mine is an older jeep.
Yours will run more like 130, but you'll get bushings for leaf springs, body mounts, sway bar, 4 tie rod ends, pinion bar snubber. See for yourself at 4wd.com, the 1 inch lift is on same page (178). Before you buy, check out quadratec.com as well for thier kit.
cjryder is offline
post #8 of 8 Old 09-13-2002, 03:47 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
I see that kit. I don't think I'll need all that stuff because I got new spring busings already and I'll be getting all new tie rod ends soon too. So, all I need it the body bushings.
Thanks,
need bolt size for v8 motor mount bolt to frame rcgkaw Jeep CJ Forum 3 08-25-2009 09:16 PM
Help with engine ID 85CJ Tom Rex Jeep CJ Forum 3 06-18-2007 10:50 AM
Will a tf999 from a 89 wrangler fit my 85cj? spamman450 Jeep CJ Forum 2 05-04-2007 09:56 PM
85CJ Exhasut Manifold to Pipe Gasket? bmtj-cj7 Jeep CJ Forum 13 07-05-2004 12:33 AM
85CJ spare tire carrier and 33" 15x8 Jeep Daddy Jeep CJ Forum 5 09-20-2002 08:12 AM
