Bolt size - JeepForum.com
post #1 of 5 Old 08-14-2003, 07:01 PM Thread Starter
TonyTJ
TonyTJ's Avatar
Bolt size
Does anyone know what size bolt holds the fenders to the grill??
Thanks
Tony
'06 LJ on 33's
'12 WK2 Limited QTII 5.7L 730N Black with Light Ash Interior.
2004 GTO
404 rwhp / 396 rwtq
TonyTJ is offline
post #2 of 5 Old 08-14-2003, 07:36 PM
CSP
5/16" coarse thread. Make them about 1" long and that should do the trick.
CSP is offline
post #3 of 5 Old 08-15-2003, 05:41 AM
mad_scientist
you need 6 of them, they are of the same style to bolt in some radiators (same on mine)
. . . end transmission . . .
mad_scientist is offline
post #4 of 5 Old 08-15-2003, 08:22 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Six or Eight ?
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #5 of 5 Old 08-15-2003, 09:09 AM
aviator
aviator's Avatar
Hit the local parts store and ask for 5/16 x 18 x 1 fender bolts. you will be needing 6 of them. - of course this is only if you want to go back OEM style.
I like the fender bolts because the have a small "unthreaded" section at the tip of the bolt. Makes it easier to get the bolt started.
Of course, any 5/16 x 18 (coarse) x 1 bolt would do I would imagine. Just Make sure and use WASHERS if you don't use fender bolts!!
Ricers make great Jack stands! Give 'em a try!
aviator is offline
need bolt size for v8 motor mount bolt to frame rcgkaw Jeep CJ Forum 3 08-25-2009 09:16 PM
SOMEBODY has to know this OEM bolt size... darowden Jeep CJ Forum 11 07-06-2009 03:34 PM
Bolt size help!!!!! hugedodge2000 Jeep CJ Forum 1 05-30-2009 09:33 PM
Need help with bolt size COBRA5LADDICT Jeep CJ Forum 2 06-11-2008 03:18 PM
what size are the torx bolts? (the actual bolt, not the "t" size) NJCJ7 Jeep CJ Forum 5 11-09-2003 09:48 PM
