bolt in sbc mounts/t176 combo question - JeepForum.com
post #1 of 2 Old 03-29-2010, 08:33 PM Thread Starter
rodjr
1980 CJ7
anybody have this set up? im wondering if the m.o.r.e engine mounts will allow the t176 to bolt in factory holes? im also wondering if ill be able to run my pully set up w/long water pump? what about the transdapt mounts?
rodjr is offline
post #2 of 2 Old 03-29-2010, 08:41 PM
Scooter402
I used to run that setup... yes, it will let you run the T176 in the factory holes, if you run the engine/trans in the factory "offset" position. I don't know if those particular motor mounts will do that, or center it between the frame rails...if it centers the engine, you'll just have to move your holes over by 1 1/2 - 2". Long water pump with pulleys, flex fan, all that will be just fine. You don't need to get a short pump to fit. Couldn't tell ya on the transdapt mounts. Good luck!
Scooter402 is offline
T176/300 combo leaks? caleb7mm Jeep CJ Forum 11 05-07-2009 05:10 PM
SR4 and T176: same bolt pattern? slowTJ88 Jeep CJ Forum 3 09-19-2008 10:59 PM
Bolt Specs for T176 Transmission to Bellhousing Full Tank Jeep CJ Forum 1 09-05-2008 06:27 PM
Will a T176 bolt up to a D20? Matt in TN Jeep CJ Forum 3 10-20-2005 06:45 AM
Skid Plate won't bolt up to T176 conversion, Help! thompsong Jeep CJ Forum 6 11-15-2004 09:05 AM
