Bolt grade equivalents - JeepForum.com
post #1 of 4 Old 08-25-2002, 08:56 PM Thread Starter
2JeepOrNot2Jeep
Question Bolt grade equivalents
After wrassling with the rusty bolts that hold on my front bumper, I decided that I wanted to replace them with stainless steel. The problem is I don't know if they make a SS bolt that is stronger than a grade 5. I have heard that 316 SS might be a grade 5, but that was just hearsay and I have no proof to back that up. Anybody have an idea where I can get a chart similar to SAE for SS (or even galvanized for that matter). Obviously I could just use larger diameter bolts, but I would rather do things the right way and find out exactly what I need. Anyway, if any of you have any good links or sources for the info I am seeking, I would greatly appreciate it. Thanks in advance!
2Jeep of course!
'86 CJ-7 Renegade
2JeepOrNot2Jeep is offline
post #2 of 4 Old 08-25-2002, 10:35 PM
dana60cj
dana60cj's Avatar
These Guys might know?
These guys seem to be scientifically into their bolts and stuff.
Here is a link where you can ask them something.
http://www.boltscience.com/pages/question.htm
dana60cj is offline
post #3 of 4 Old 08-26-2002, 08:44 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Here's your solution, just go up one notch. No need to spend $$ on specialized parts.
Start using Grade-8 Bolts (6 Lines) You can find them at Lowes/Home Depot or even order through Grainger. They have a tensile strength of 150,000lbs, and usually gold/zinc plated and resist rust very very well. Also use Anti-sieze anytime you drop in bolts. These are very hard to break.
Stainless are the best for resisting rust, but are only equivilant to Grade 5, sometimes less. ( 110,000lbs)
Grade 5 are usually zinc coated and tend to rust quick, but still better than grade 2-3 or regular zinc bolts..
Hope this helps
K9Jeep
K9JEEP is offline
post #4 of 4 Old 08-30-2002, 09:13 PM Thread Starter
2JeepOrNot2Jeep
Hey K9JEEP,
I have been gone most of this week on travel so I haven't had a chance to check my email. The bolts that I removed originally were Grade 8 bolts and unless they changed how Grade 8 bolts are made, mine were very rusted. Cutting off two bolts took almost a whole cutting wheel (granted they were cheesy ones)! Anyway, from what I have read over in JU, Grade 5 bolts or higher are recommended for bumpers. All in all I have gotten conflicting reports from people I know and people I don't know. What I am sort of looking for is some sort of comparison charts on regular steel bolts (diff grades) and SS bolts. I guess a chart on tensile strengths would be a start, but how about torque values? Does that really matter in this application? I guess this is turning "bolts for dummies" thread...
Thanks in advance!
2Jeep of course!
'86 CJ-7 Renegade
Grade 8 Bolt/Rust Question! CJman77 Jeep CJ Forum 31 02-26-2009 10:49 AM
grade my improvement? sakisaki400 Jeep CJ Forum 14 11-09-2008 09:53 PM
ignition up-grade hwyjeeper Jeep CJ Forum 4 10-17-2008 05:14 AM
What oil grade should I use? Clem82389 Jeep CJ Forum 10 08-25-2008 08:42 PM
Steering Box Up grade? elks96 Jeep CJ Forum 6 07-06-2008 12:48 PM
