Boiled Linseed oil? - JeepForum.com
post #1 of 12 Old 06-01-2010, 10:13 PM Thread Starter
jwhi1979
1979 CJ7
Boiled Linseed oil?
I have read several post saying that boiled linseed oil can be used to coat the inside of my cj frame. Most of the posters were doing a frame off resto which im probably not going to do. My questions are:
Can I spray the linseed oil into the frame with out doing a frame off and if so are there any special precautions to take?
Where can I find linseed oil?
jwhi1979 is offline
post #2 of 12 Old 06-01-2010, 10:23 PM
mtbtweety
mtbtweety's Avatar
1982 CJ8
Lowes / Home Depot has it. It's used to rust proof metal tables, vices, etc. Curiously, it's also used to treat the threads on spokes prior to bicycle wheel building because it's lubricating until it hardens...
mtbtweety is offline
post #3 of 12 Old 06-01-2010, 10:40 PM
kakai81
Linseed oil is the base to linoleum. It's a great sealant. However, I don't know how long it would last, or how well it would stand up to the elements. Even inside your frame it would still get hot and wet sometimes. If you're going to spray it in anyway, why don't you just spray in POR-15? It's made for that purpose, and it will last.
kakai81 is offline
post #4 of 12 Old 06-02-2010, 04:27 AM
tigercreek
I use it on bee boxes and outdoor tables.
I have never experienced it as a permanent fix - it requires maintenance.
Just sitting in the elements it wears away.
I can't imagine it holding up in driving conditions.
No matter where you go, there you are.
tigercreek is offline
post #5 of 12 Old 06-02-2010, 05:58 AM
rixcj
rixcj's Avatar
1979 CJ5
I used it inside my frame, but I did do a bare frame restoration. In your case, you should try to get as much loose debris out of your frame as you can. There is typically a lot of stuff accumulated inside jeep frames. If you don't get this crap out, the linseed oil won't actually coat the frame, it'll just lie on top of all the loose stuff.
Also, it doesn't really "spray", at least not with a garden type sprayer. It just "pees" out. Getting this oil to completely coat the inside of the frame, is VERY challenging. You wouldn't believe what I went through.
The point is, no matter what you decide to use, as much of the loose stuff as possible has to be removed.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #6 of 12 Old 06-02-2010, 06:12 AM
DCHCJ7
What you want is something that will put a waxy film on the inside.
2 of the best products for this are below.
Waxoyl - US Distributor - RoversNorth.com. The Source For Corrosion and Rust Protection for your Automobile. Clean. Protect. Preserve.
Heavy Duty Anti Rust Qt 32oz
Waxoyl is very well known in the Land Rover community. the Eastwood antirust i used it on my own Land Rover (to cheap to buy Waxoyl) this worked great.
For the areas that there is no access the you have to drill holes and the kit comes with plugs.
I would look at this and get the gun with it. You can get all areas of the inside of the frame.
POR 15 is great for the outside of the frame, but for the inside the stuff above is what your looking for.
DCHCJ7 is offline
post #7 of 12 Old 06-02-2010, 09:42 AM
turbogus
1978 CJ5
shows where my head is at this morning
On a serious note, I'm a POR15 and metal ready advocate too
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is online now
post #8 of 12 Old 06-02-2010, 02:09 PM
JeepHammer
Running On Empty...
1973 CJ5
Boiled Linseed oil is some NASTY crap to work with,
But it works VERY well, is cheap, and doesn't take tons of prep to use.
Usually what I do is use pressure washer, and spray out the areas I'm going to coat,
Or use a sand blaster where you can,
Then get a cheap plastic pump sprayer (Something you can throw away instead of cleaning... Cleaning up afterwards is the hard part!)
Spray the linseed oil in where I don't want rust to happen,
Let it dry a week or so,
And give it another coat.
Second coat dries MUCH faster.
This stuff is VERY difficult to get off, so pay attention to where it's getting when you apply!
Two or three coats is usually enough if you let them dry good between applications.
It's a 10 year rust proofer, but god help the guy that has to remove it!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 12 Old 06-02-2010, 08:27 PM
86cj74.2L
86cj74.2L's Avatar
My dad used the stuff to cote his masonry tools so they wouldn't rust. I use them now and he hadn't used them since the late 60's... Still in great shape.
86cj74.2L is online now
post #10 of 12 Old 06-02-2010, 08:45 PM
DCHCJ7
only thing I have used Linseed oil on is the stock of my Enfield No2 Mk IV rifle does a nice job but i would not use it on anything else.
DCHCJ7 is offline
post #11 of 12 Old 06-02-2010, 09:19 PM
RangerRick
Likewise on my WWII Springfield M1 Garand....
RangerRick
RangerRick is offline
post #12 of 12 Old 06-23-2013, 11:41 AM
Yoda95
I just used this combo because of the posts on this forum, and I am duly impressed! It made my plastics look fantastic! Thanks everyone
Yoda95 is offline
Axls and Leaf springs coated with Boiled linseed oil semaJ Jeep CJ Forum 5 01-27-2010 01:17 PM
