Body Tub questions/opinions - JeepForum.com
post #1 of 13 Old 01-11-2010, 07:29 PM Thread Starter
IHPuller450
1983 CJ7
Ok guys so i have purchased 2 tubs in addition to the one that is currently on my jeep which is steel. one is steel off of a yj and the other is fiberglass off of a cj. now the question im posing to you is which of these would be my best option? the fiber tub is broken and both steel tubs are very rusty...
im going to link to my facebook album of them if you have a facebook you should be able to see them and if someone could make them click free that would be great! thanks guys!
Current tub:
Ben Jones | Facebook
Fiberglass tub:
Steel Tub:
Thanks again!
"Manual transmissions are too distracting, they interfere with eating, napping, texting, drinking, shaving, phone calling, makeup application, reading, bird flipping, DVD watching...................................etc.
You know, all the important stuff that needs to get done while people are behind the wheel."
IHPuller450 is offline
post #2 of 13 Old 01-11-2010, 07:36 PM
-AC-
1977 CJ5
Well, I don't socially-engineer, so I can't see your pics. But, just to try to give you some response, at least until the Facebookers chime in, I guess I would think that Fiberglass is easier to fix than rust, and cheaper. Plus, once you're done fixing it, it won't re-rust as steel will. So, I like fiberglass, but that's just me...
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #3 of 13 Old 01-11-2010, 07:40 PM Thread Starter
IHPuller450
1983 CJ7
yeah, that is my opinion too but the fiber is broke just under the windshield frame mount... its going to be a pain to fix, not that i couldnt just difficult. plus i like to weld alot more haha
post #4 of 13 Old 01-11-2010, 07:43 PM
rixcj
rixcj's Avatar
1979 CJ5
Sounds like you just answered your own question!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #5 of 13 Old 01-11-2010, 10:28 PM
BeatCJ
1981 CJ5
Looking at the pics, the fiberglas tub is shot and beyond repair. Of course, so is the red steel tub. If I were you, I would keep looking for a replacement. At least the tub on your Jeep is straight, on those 2 tubs the structure and reinforcements are in weak enough that the tubs are twisted out of shape.
There are some things you will learn while holding a cat by the tail that can be learned no other way...
BeatCJ is offline
post #6 of 13 Old 01-11-2010, 11:08 PM
jeepsterdk
1978 CJ7
My thoughts exactly. Those two bodies aren't worth much effort. They would both be too time consuming to fix, and if you're not an expert in fiberglass fixing or welding, I don't believe you would be 100% satisfied with the end result. But then again, I'm kinda anal when it comes to building old Jeeps
If your on a budget, try to find a better YJ body and re-locate the body mounts so it will fit your '7. If money is not a big issue, go for a new FG tub. That is what I did, and so far, I'm very pleased with it. (Although money is kinda an issue with me, I got a tax return which helped finance the FG tub and front end )
1978 CJ7 | 360 AMC | TH400 | AMC20 | YJ springs
jeepsterdk is offline
post #7 of 13 Old 01-12-2010, 12:08 AM
scottymac62
1979 CJ7
Which one is the YJ tub? Because the ones I see all have major rust on them, and YJ's normally don't rust that bad since they where galvanize dipped.
I went with the rust free YJ tub route myself, and am very pleased with the results.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #8 of 13 Old 01-12-2010, 04:12 AM
84MSRB
Look up or call Daveys Jeeps in Salem, OH. A jeep graveyard.
1984 CJ7 Mud Slingin Rust Bucket
90 YJ tub
Ford Mutt 5.0( 69 block, 89 EFI)
84MSRB is offline
post #9 of 13 Old 01-12-2010, 08:17 AM Thread Starter
IHPuller450
1983 CJ7
the red steel tub is the one off of the yj, and yes i was also dissapointed with how rusty it was. Daves jeeps in ohio is a great place although they always seem to be lacking in the cj/yj tub area lol.
You dont think that corner is fixable on the fiber tub? i thought that if i put it on the frame and then using the proper dimentions held it in place to fix it it could be done. The only issue with that is that the structure under the windshield would be iffy, but since i am planning a full cage for it i thought i might be able to tie a support in to hold that area stabe. any thoughts on this?
thanks again guys!
post #10 of 13 Old 01-12-2010, 08:59 AM
Mike Romain
The fiber tub looks to be cracked on seams on the side, nice clean break anyway.
The door post can get a steel backing support that can integrate the bottom door hinge bolts and the top hinge bolts to clamp it solid. It then could be 'glassed from the back. I also cracked mine right below the windshield/door hinge plate and that is what I plan on doing. I am thinking some pieces of carbon fiber might be called for in there too.
When my tub was made, diamond plate was sandwiched in places like where the steering wheel and brakes are to beef it up. I would think you could also use some small steel plates across the cracks and sandwich them in for reinforcement. Then there are carbon fiber sheets that are real strong.
I would sure clean it out to have a good look at it anyway.
Mike
Mike Romain is offline
post #11 of 13 Old 01-12-2010, 10:15 AM
BeatCJ
1981 CJ5
Sure, the 'glas tub IS repairable, but it depends on what you want out of it. I see the breaks on the rockers under the doors, and the damage to the cowl support, a crack in the cowl, it looks like to me it probably has no subframe/support left. I bet it's just destroyed.
BeatCJ is offline
post #12 of 13 Old 01-12-2010, 08:33 PM Thread Starter
IHPuller450
1983 CJ7
the rest of the fiber tub seems to be in decent shape, aside from those few breaks. the PO of the tub told me that it hadnt been mounted for that long when he rolled it over, and the jeep did have a cage in it so i dont think it affected the understructure of the tub that much but i could be wrong there.
i just want to make some progress on it... its been sittin in the driveway for over a year now and i havent done anything except get it running, i guess being 2 hours away at school dosent help that much either...
post #13 of 13 Old 01-13-2010, 09:59 AM
BeatCJ
1981 CJ5
So those breaks are from the roll over? Again, to me that's a red flag. Maybe you could repair it, but I think it will be a huge amount of work. I think the best tub of the three you have is the one on it, but I could be wrong. Mike is right though, clean it out, roll it over and look at the underside. Do you know anyone that does fiberglas work? Get their advice. it's really hard to give good advice looking at Internet pics.
I think you should look for a different YJ tub. It will save you time and money.
BeatCJ is offline
Should I remove body lift? Opinions? Jeremy_C Jeep CJ Forum 20 01-21-2010 01:12 PM
More questions: Looking for opinions on bucket seats Daladim Jeep CJ Forum 12 12-10-2009 09:11 PM
need opinions about throttle body injection Mc83J10 Jeep CJ Forum 3 06-28-2008 05:12 PM
Opinions on body high51977 Jeep CJ Forum 13 02-28-2008 04:13 PM
Replacement Body Opinions oldcatcher Jeep CJ Forum 16 08-20-2002 06:32 PM
