Body tub help - JeepForum.com
post #1 of 4 Old 05-22-2002, 02:29 PM Thread Starter
johnnyamc
Question Body tub help
I have a 1978 Jeep CJ7. It has a bestop on it. It leaks like a paper bag. I plan to replace it with a hard top once I put a motor in the jeep. My question is the 81/82-95 CJ7 and Wranglers use door strikers. Are the tubs different or the same on my 78 if I wanted to put on door strikers and a Wrangler top. I was looking at them on ebay and compared with my Jeep and it did not look as if they would work. Any help would be greatly apprciated.
1978 Jeep CJ-7 T-400 Q-Trac New 304 edelbrock intake and 4 barrel carb, comp cam, .060 over, dogleg heads and it DOES have some power.Forget swapping in a 350 chevy. Always AMC.
johnnyamc is offline
post #2 of 4 Old 05-23-2002, 07:47 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Get a new set (or good used) set of strikers, and everything will match up just fine.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 4 Old 05-23-2002, 11:12 AM
GroundUpCJ7
Post
The hard top is identical, the doors are different. If you get the stock doors for anything before 81, you don't need the strikers, if you get anything 81 and after, you need the strikers.
It's not so much a labor of love as it is shear determination.
GroundUpCJ7 is offline
post #4 of 4 Old 05-23-2002, 03:20 PM
yj7redlion
Post
the tubs are slightly different with the 81's and newer having a raised panel behind the door to accept the stricker. since 81 and pioror hooked to the dioor jamb the don's have it. You may be able to retro fit it but i don;t know of anyone that has tried that.
78 cj7 soa yj tub swap. 360 t18.
yj7redlion is offline
jeep floor rebuild+body support rail+ 1" hockey puck body lift canadianwinter Jeep CJ Forum 46 03-12-2010 12:26 AM
body mount bushing/body lift???? rnw77cj5 Jeep CJ Forum 6 12-28-2007 08:49 AM
Anyone know where to find replacement body mounts, the ones on the body supraman1990 Jeep CJ Forum 2 07-24-2007 01:29 PM
Body sits unevenly on frame, and its is not the body mounts!!! jatepper Jeep CJ Forum 16 05-08-2007 02:45 PM
crooked body, stupid body lift k2stew Jeep CJ Forum 11 04-27-2007 10:26 AM
