Body tub advice - JeepForum.com
post #1 of 6 Old 03-22-2004, 10:02 PM Thread Starter
mcc86cj7
Body tub advice
Ok finally time to tackle replacing the body.
Engine, Tranny, Transfer,Exhaust, axles, shocks, and springs all done
but the body is finally dropping off in chunks.
Any one out there have any feedback on:
1.Aluminum body
2.Steel Body (rhino lined)
3. Kevlar body (gotta love bullet proof fibers)
I wont be doing all the work myself but will have to fork out funds for someone else to do this and i am leaning towards the steel replacement body just for ease of installation and turn around time.
Any thoughts?
86 cj7 Renegade
mcc86cj7 is offline
post #2 of 6 Old 03-25-2004, 06:51 PM
Boiler
Hey dude....I did the YJ body swap on my 84 and it couldn't have been easier. I went the extra mile though and moved my CJ tailgate over. Only real mods to get the YJ tub to bolt up is move the body mount holes on the rear crossmember out about 3/4 inch. Other than that, everything bolts up just fine.
Hope this helps...
Marc
Boiler is offline
post #3 of 6 Old 03-26-2004, 10:40 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I am not trying to give advice but here is what I did.
Bought an Aluminum Body from JP Off Road, so far it is on the money for mounting pad location and angles built in to the body.
There are no holes in the tub at all, even the body mounting pads are set up so you don't have to open the inside to the outside.
The door, hood and tail gate mounting points are reinforces with an additoina 5/16th aluminum in side of the body, again you don't have to drill through but I think the hinges will be more secure with through bolts.
The weight, four people can handle the CJ8 tub without a problem.
Drilling the aluminum to mount everything is best done using "Auto Trans Fluid" as a lube (A MUST).
Keep your old body as a templet, just incase you have a measurement question.
Anything else, just ask.
Later,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #4 of 6 Old 03-26-2004, 11:20 AM
2cjs
2cjs's Avatar
Get a yj tub. find one thats not damaged and not rusted out,there are good tubs out there,Ijust bought one a week age for 550.00 great shape no rust.
If you go with a yj tub here are a few things I found out when I did my 83 cj-7
1)2 body mounts, the 2 in front of the rear tires must be moved(one on each side)then its a direct bolt on.
2)go with a hydraulic clutch(much easier to do)
3)you can use your instrument panel off your cj
4)I used a yj windshield frame
5) I welded my tailgate hinges to the tub so I could use my cj tailgate
6)might want to use a yj gas tank because your filler nozzle is on the opposite side of the jeep
just a few mods and your good to go.I think if you buy a yj tub and buy the parts you need to get her done ,you probably will spend the same amount then just buying a fiber or alum tub. thats just my opinion.
good luck ,keep us posted on your project.
btw boiler ,you moved just 2 mounts on your crossmember?just wondering because I just had to move 2 mounts that are on the outside of the frame
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline
post #5 of 6 Old 03-28-2004, 04:50 PM
bstruckm
bstruckm's Avatar
I would caution you not to use a YJ gas tank and keep the filler on the driver's side because your exhuast pipe would then be directly underneath your fuel filler. Probably not the best plan.
Your better of cutting a hole on the passangers side and using a CJ tank.
Use the license plate braket off a YJ and it will hide the extra hole. Or get some diamond plate corners and cover it up.
bstruckm is offline
post #6 of 6 Old 03-30-2004, 01:21 PM
T Hoff
1975 CJ5
For drop-on, stay with the steel. If you got time you can go with the Fiberglas Like I did. My CJ has been glass for 11 years now. It's a 4WD body with a AJ one piece nose. It was my daily driver for a while. The 4WD body is a strong one. Some are junk.
You do have to be creative though. There are no holes. You get a jacuzzi shaped like a Jeep.
I have no experience with the Aluminum bodies.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
Need some advice on Body work genghisman Jeep CJ Forum 5 12-17-2008 12:58 PM
Need Some Advice - Body Panels GP_Pete Jeep CJ Forum 14 09-14-2007 09:42 AM
I need your help again(body advice) Phatty Jeep CJ Forum 6 08-24-2006 12:25 PM
need some advice on my body MFairbourn Jeep CJ Forum 6 12-02-2002 02:25 PM
shackles or body lift? any advice? pete77 Jeep CJ Forum 8 07-23-2002 08:50 AM
