body panels - JeepForum.com
post #1 of 9 Old 06-07-2009, 09:13 PM Thread Starter
careed
body panels
I know its a weird question but looking at buying a welder to do some sheetmetal repair on my jeep what is the gauge of the sheetmetal on the body panels and which way does the scale go for instance which is thicker 12 gauge or 24 gauge probably should know this but have never dealt with sheetmetal before thanks chris
careed is offline
post #2 of 9 Old 06-07-2009, 09:37 PM
Shrevmo
Lower the gauge the thicker and get the best welder you could afford. Don't just buy a welder to sheetmetal....get one that can weld 1/4".
Its only money....I'll make more tomorrow!!
Shrevmo is offline
post #3 of 9 Old 06-07-2009, 09:41 PM
scottymac62
1979 CJ7
Most of the Jeep body replacement panels are 16 or 18 gauge. The lower the number of the gauge, the thicker the metal.
I use a MIG welder with .030 solid MIG wire and CO2 gas to do most of my panel welding. I also use .035 flux core wire for heavier applications.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #4 of 9 Old 06-07-2009, 09:53 PM Thread Starter
careed
im looking at the lincon 125 would that be pretty good for everything jeep related
careed is offline
post #5 of 9 Old 06-07-2009, 10:58 PM
frankush
This is very good advice. The Lincoln 125 will really only be good for sheet metal work. If you want to run anything thicker you'll have to make multiple passes, which means 2 to 3 times the work and wire. For just a few bucks more, you could easily upgrade to a higher capacity mig. If your stuck using a 120V machine look at the 140A models. Most with be set up for use with shielding gas. If you have 240V available, look into a 180A model. These machines are great for just about anything you'll have to tackle around the home or on any Jeep. Both of these mig welders can be dialed down for sheetmetal work and do an impressive job. It may be more than you want to spend, but if you buy a quality 180A mig, once your work is done, you could easily sell it for almost what you paid for it.
Outfits like Northern Tool and Tractor Supply Co. often sell the Hobart 187 for just under $600. The Lincoln's are probably about the same or a little less at any of the home centers.
frankush is offline
post #6 of 9 Old 06-08-2009, 06:51 AM
rixcj
rixcj's Avatar
1979 CJ5
Here you go...
http://www.sheetmetalguy.com/sheet_m...auge_chart.htm
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #7 of 9 Old 06-08-2009, 08:10 AM
Pathkiller
1974 CJ5
Just like shotguns, a 12 gauge is bigger than a 20 gauge.
Pathkiller is offline
post #8 of 9 Old 06-08-2009, 09:38 AM
jsc7002
1966 CJ5
that supposed to be a pretty good welder, dont get the 125ez though, because its flux core and is MUCH harder to do sheetmetal with because flux core will burn hotter than a regular MIG welder.
another good welder is the Hobart Handler 140, my friend has one and we have welded 1/4" with it and it did a great job!
jsc7002 is offline
post #9 of 9 Old 06-08-2009, 10:14 AM
attworth
1979 CJ7
I'll second the advice to get a good MIG setup. Flux-core will work well for odd jobs and stuff that doesn't need to be pretty, but MIG is much better, especially for body work. You can usually find good used machines for pretty good prices. I bought my flux-core, knowing what it would and wouldn't do, for about 100 bucks. I can't remember the model number, but it's a nice machine. I just wouldn't use it for body work. (Ugly welds, lots of spatter.)
attworth is offline
72 Body Panels Glock23NC Jeep CJ Forum 2 03-23-2009 03:10 AM
Need Some Advice - Body Panels GP_Pete Jeep CJ Forum 14 09-14-2007 09:42 AM
Body Panels Dandude80cj7 Jeep CJ Forum 2 09-06-2005 01:19 PM
Need replacment body panels Notplayn Jeep CJ Forum 3 04-06-2004 06:53 PM
Decent Body Panels aviator Jeep CJ Forum 2 06-18-2003 04:19 PM
