Body Panels - JeepForum.com
post #1 of 6 Old 05-26-2010, 05:30 PM Thread Starter
kluman
1979 CJ5
Body Panels
Has anyone used the body panel adhesive instead of welding?
kluman is offline
post #2 of 6 Old 05-26-2010, 06:40 PM
jscherb
I've used it to replace floor panels, and I highly recommend it. I documented the job in the Gaucho pickup build thread, you should be able to find it with a search (or by following the link in my signature to that thread).
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #3 of 6 Old 05-27-2010, 04:32 AM
keith460
Jeep. There's Only One
keith460's Avatar
I used it also to mount in the support baffles that are inside the rear wheel houses as the Repli-tubs do not come with them. Also mounted the battery tray threaded support brackets to the firewall since the spot welder I had could not reach in to do the job. It is just as strong as spot welding as long as you mix equal parts of the adhesive together. Highly recommend it as it is easy to work with.
1984 CJ-7 Renegade
keith460 is offline
post #4 of 6 Old 05-27-2010, 09:14 AM
dieselgriz
Do you have a specific brand that you use? Could you take post a picture of it or a link? Where did you get it at?
dieselgriz is offline
post #5 of 6 Old 05-27-2010, 10:08 AM
keith460
keith460's Avatar
3M brand I believe and they make a lot of sealants and adhesives for the auto industry. Bought mine from NAPA off the shelf.
Website URL: 3M
1984 CJ-7 Renegade
keith460 is offline
post #6 of 6 Old 05-27-2010, 11:28 AM
dieselgriz
Thanks, I will check it out.
make body panels or buy them kurtrod Jeep CJ Forum 13 11-10-2009 08:57 AM
body panels careed Jeep CJ Forum 8 06-08-2009 10:14 AM
72 Body Panels Glock23NC Jeep CJ Forum 2 03-23-2009 03:10 AM
Replacement Body Panels steveracer67 Jeep CJ Forum 2 03-14-2007 09:44 AM
Body Panels Dandude80cj7 Jeep CJ Forum 2 09-06-2005 01:19 PM
