Body Mounts Problem - JeepForum.com
post #1 of 3 Old 08-11-2002, 08:09 AM Thread Starter
Boots
Unhappy Body Mounts Problem
When I recently pulled the tub of of my CJ5, several of the body mounting bolts wouldn't come out and I had to saw them off. It would appear that up in the body supports have a nut welded inside where you can't get to it, and apparently the welds have broken off. Basically, I kept turning the bolt and it never came out until I got the grinder out and cut off the bolt head.
Any ideas on how to correct this?
Boots
Boots is offline
post #2 of 3 Old 08-11-2002, 08:19 AM
martyb
I'm wondering this too. I'm afraid to take my mounts out to replace them.
I was thinking... just drill a hole through the floorand put a bolt all the way through. Is this a good solution?
martyb is offline
post #3 of 3 Old 08-11-2002, 08:31 AM Thread Starter
Boots
Thats certainly a potential solution. I'll have to look at where the bolt heads would be located and make sure they don't interfere with seat mounts or anything else.
It looks like a major body work job to cut out the floor pans.
boots
Boots is offline
Anyone know where to find replacement body mounts, the ones on the body supraman1990 Jeep CJ Forum 2 07-24-2007 01:29 PM
Body sits unevenly on frame, and its is not the body mounts!!! jatepper Jeep CJ Forum 16 05-08-2007 02:45 PM
which body mounts rmballou Jeep CJ Forum 2 05-31-2006 02:34 PM
Body Mounts/Body Lift Question CAH Jeep CJ Forum 2 02-12-2005 08:33 AM
body mounts beachcruzr Jeep CJ Forum 1 08-15-2002 05:31 AM
