Body mount captured nut cage replacements - JeepForum.com
post #1 of 4 Old 10-03-2011, 09:29 AM Thread Starter
89 JeepYJ
1984 CJ8
I am in the process of replacing rusty floor pans on my cj8 and then I am going to pull the body off so can clean/paint/protect frame and underside of tub. Anyway while I have the driver and passenger side floor pans out I decided to go ahead and loosen the body mount bolts encase I had any problems with the nuts spinning. Sure enough two of the little sheet metal captured nut cages have rusted away to nothing. I want to go ahead and fix this before I weld in the new floors since I currently have good access to them. Question is can I buy those sheet metal cages or will I have to make them? Or is there a better solution than those. I thought about just welding the nuts to the body bracing, but that won't allow any adjustment when I go to line the body back up for tub re install. Any help would be appreciated since progress on this frame off is at a standstill until I get this resolved.
89 JeepYJ is offline
post #2 of 4 Old 10-04-2011, 09:13 AM Thread Starter
89 JeepYJ
1984 CJ8
Come on I know that some of you guys have run in to this same problem. How did you fix it?
post #3 of 4 Old 10-04-2011, 01:44 PM
Fatman
Fatman's Avatar
2008 CJ7
Fab up the cages out of 16 ga sheet, drill a 1/2" hole in the center. Then cut a piece of 1/4" that will fit into the retainage cage with about 1/4" of room. Drill and tap the 14" stock for the body bolt thread and weld the new cage back into the rail. Simple stuff.
Thread Links:
Fatman is offline
post #4 of 4 Old 10-04-2011, 02:17 PM Thread Starter
89 JeepYJ
1984 CJ8
I figured that is what I was going to hear. I was hoping that there was another way I just hadn't thought of yet. If only I had a shear and sheet metal brake at home.
Captured Nut Repair- Frame Skerr Jeep CJ Forum 27 04-30-2015 11:39 AM
Frame-to-Body mount Replacements stearman42 Jeep CJ Forum 11 09-19-2011 10:24 PM
Roll cage to frame mount 78treehugger Jeep CJ Forum 12 02-05-2010 06:48 PM
CJ Dash mount cage, any pics?? firejeep344 Jeep CJ Forum 2 07-06-2009 07:08 AM
Roll cage mount Gummo Jeep CJ Forum 4 01-17-2008 01:46 PM
