Body Mount Bolts - JeepForum.com
post #1 of 5 Old 03-17-2008, 05:36 PM Thread Starter
Redmanchew
Redmanchew's Avatar
1982 CJ7
Body Mount Bolts
Please notice i said body mount, not body lift. While doing my bushing swap this weekend from stock to stock i remember someone asking a long time ago what size bolts hold everything together... so for reference...
On a 82 CJ-7...
Radiator is a 7/16 14tpi x2 1/2"
Two behind the front tires 3/8 16 TPI x 3"
Next two sets and the two on either side of the gas tank 3/8 16 TPI x 2 1/2"
Finally rear bumper pair are back to 7/16 14tpi x 2 1/2"
Qualifier... This is for stock with a new set of stock daystar bushings.
If someone else can fill in the OD on the washers (obviously the ID is the bolt size) and info on the sleeves it can all be in one place for reference.
All of theese bolts were available in stainless at local Lowes for less then $20.
Thanks again for everyones help through the years!
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #2 of 5 Old 03-17-2008, 07:57 PM
John N
1981 CJ8
The best you can do is usually to get the oversize fender washers. If you want stainless, West Marine on Broad St (Richmond's west end) has them.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 5 Old 04-02-2008, 09:43 AM
jfwireless
1976 CJ7
I used some large galvanized square washers used by utility crews on telephone poles when converting over to a fiberglass body for the body mount bolts.
Jim
jfwireless is offline
post #4 of 5 Old 08-14-2011, 03:01 PM
wallyJEEPIN
Front BMB
I was installing 2 inch body lift and front body mount under grill snapped any ideas how to get it out?
wallyJEEPIN is offline
post #5 of 5 Old 08-14-2011, 03:17 PM
jeepwhore
Ancient thread, but you are looking for help rather than just adding "x2" to someone's comment.
So the bolt snapped? Not what you want to hear but you are going to need to take the grille right out so you can cut a hole in the bottom of the mounting surface. Then fish out the broken bolt and thread plate, replace the threaded plate and weld the access hole shut.
You might be able to do it with the grille in place by cutting the top of the mount open to remove the old thread plate but that depens on how much of the bolt is sticking out. Did it break off flush with the thread plate? Or did the head snap off?
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
Cant Remove Body Mount Bolts Cowtown76CJ5 Jeep CJ Forum 4 07-19-2009 10:41 PM
Need new body mount bolts. HELP jatepper Jeep CJ Forum 4 07-19-2007 12:21 PM
Rear body mount bolts on a 78 CJ5 ETJeep Jeep CJ Forum 3 06-22-2007 09:08 AM
Removing body mount bolts ETJeep Jeep CJ Forum 1 02-10-2007 07:41 AM
Body Mount Bolts... collinpyle Jeep CJ Forum 3 10-02-2006 03:59 PM
