Body lift vs. Suspension Lift - JeepForum.com
post #1 of 5 Old 02-09-2006, 07:03 PM Thread Starter
jmreagan
jmreagan's Avatar
I just bought my first jeep. It is a stock 03 TJ sport. I want to fit bigger tires than the stock 31x9.5's it came with. I would like to put 32x10.50's on it. My question is which lift is better body or suspension? The body lift is really affordable and I could do myself easily. I only want to lift it 2 inches. I could do the suspension kit but I don't want to deal with brake lines or any other mods. Is it really worth it for the suspension lift? What are the advantages of each? Thanks!
jmreagan is offline
post #2 of 5 Old 02-09-2006, 07:15 PM
CJmadison
Body lift will just give you the clearance for bigger tires.
CJ Madison
2006 TJ... bone stock
CJmadison is offline
post #3 of 5 Old 02-09-2006, 09:00 PM
Wolf359
WOLF359
Wolf359's Avatar
The body lift is harder to do in my opinion. I put replaced my body bushings and found that a couple of mouting points are above my tank.. in a CJ. The suspension lift was a piece of cake... just leaf spring replacement.
I just realized you're in the wrong forum... this is the CJ section. There's a TJ specific area where those folks will know more about your generation Jeep
The suspension lift for your TJ will require more work because of the coils. Go with the suspension lift in any case... you'll have more clearance.
Wolf359 is offline
post #4 of 5 Old 02-10-2006, 12:10 AM
hmmhoyhoy
Like Peteman said, suspension over body. I personally think anything over a 1 inch body lift is ugly{my opinion} But theres lots of options for TJs other than just body
95 YJ
4.0 AX-15
Dana 60 f with ARB 10.25 r and open. 5.13s
37" BFG AT's
02 WJ Overland
hmmhoyhoy is offline
post #5 of 5 Old 02-10-2006, 02:49 PM
No_Bs
1977 CJ5
I helped one of my buddies put on a 2" body lift on his TJ, it was very easy, but I do not see how 32's would fit. His 31's hardly do. If your jeep has air conditioning, it's a but harder and is "impossible" in manufature's eyes, but a little bit of ingeuity can get around that I found. If you just want looks, body is kinda ugly, but if you just want bigger tires, it works. I can't see 32's fitting under a 2" body though. I would say go suspension if you want bigger than 31's.
No_Bs is offline
SPRING OVER AXLE- roughly how much lift do you get?is it better then a 4" +body lift? jeepcj7 Jeep CJ Forum 12 05-02-2012 09:33 AM
jeep floor rebuild+body support rail+ 1" hockey puck body lift canadianwinter Jeep CJ Forum 46 03-12-2010 12:26 AM
Poll: Keep 35s and Body Lift or Get 33s and no Body Lift? _Kyle_ Jeep CJ Forum 8 12-24-2009 07:12 PM
Would someone please explain the difference between a suspension lift and a body lift Giff Jeep CJ Forum 5 09-20-2007 03:49 AM
Body lift or wait for suspension romans111 Jeep CJ Forum 7 12-29-2004 05:38 PM
