Body Lift??? (Hockey Puck) - JeepForum.com
post #1 of 7 Old 03-03-2002, 12:31 PM Thread Starter
AeroViper1
Post Body Lift??? (Hockey Puck)
Has anybody used Hockey pucks for a 1" body lift?...I read somewhere that you can drill a hole in the center and pick up some bolts to do a body lift...what are the dangers of this?
AeroViper1 is offline
post #2 of 7 Old 03-03-2002, 12:34 PM
Travis
Post
Never heard of that but I don't see why you couldn't. All a body lift is are blocks of plastic. I would think that hockey pucks would be more expensive though. How much do they run?
Travis is offline
post #3 of 7 Old 03-03-2002, 09:09 PM
Bill Zebub
Post
Yes it works -- I did that on a 76 Chevy Blazer I had years ago. Drill the hole large enough to fit your bolt through, I had one split on me soon after I did it. Otherwise it held up fine - truck went to the junkyard 4 years later with the lift still there. When I did my lift I think I paid about $2 per puck. Dont but the NHL team pucks, buy the cheapest you can find, they're all the same.
Bill
Bill Zebub is offline
post #4 of 7 Old 03-04-2002, 11:03 PM
Crash&Burn
Post
I'm replacing the body of my CJ now, and the new body mount kit I'm using the stock mounts are the same thickness as a hockey puck, so I don't think you will gain anything.
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #5 of 7 Old 03-05-2002, 06:58 AM Thread Starter
AeroViper1
Post
Hockey pucks run @ $1.99 a piece plus bolts, there are 11 points between the body and the frame so $22.00 plus bolts, (how much does a grade 8 bolt, about 3" run?)...I think it'll be less than a "name brand" body lift. Crash&Burn...You put the puck between the body mount and the body...on top of the stock rubber.
post #6 of 7 Old 03-05-2002, 07:01 AM Thread Starter
AeroViper1
Post
Now that I read more...It says, for bolts, I need
6 bolts @ 4-3/4"x1/2"
5 bolts @ 3-5/8"x7/16"
Here's the link, It's a great site with a lot of info on mod installations... http://www.bc4x4.com/faqs/yj.cfm?cat=2&faqid=8
post #7 of 7 Old 03-06-2002, 11:59 AM
KeenCJ7
Post
It works well, I have an 84 CJ7 and I beat the piss out of it and I have had no problem with mine!
84 CJ7 with tons of mods
RigRater Score:
704RRv1.0 with a BOA of 23.07 -- <a href="
target="_blank">http://www.rigrater.com</a>
KeenCJ7 is offline
jeep floor rebuild+body support rail+ 1" hockey puck body lift canadianwinter Jeep CJ Forum 46 03-12-2010 12:26 AM
Poll: Keep 35s and Body Lift or Get 33s and no Body Lift? _Kyle_ Jeep CJ Forum 8 12-24-2009 07:12 PM
body mount bushing/body lift???? rnw77cj5 Jeep CJ Forum 6 12-28-2007 08:49 AM
crooked body, stupid body lift k2stew Jeep CJ Forum 11 04-27-2007 10:26 AM
Body Mounts/Body Lift Question CAH Jeep CJ Forum 2 02-12-2005 08:33 AM
