body lift - JeepForum.com
post #1 of 34 Old 08-24-2007, 07:32 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
body lift
After I do my spring over conversion I am thinking about putting a 2" body lift on. With this combo, does anyone see any problems with driveshaft or brake lines?
TetanusCJ7 is offline
post #2 of 34 Old 08-24-2007, 07:35 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
How about the clutch assembly or shifter positions
post #3 of 34 Old 08-24-2007, 07:38 PM
Bard
Brakelines and driveshaft will not be affected by the body lift. All you are doing is lifting the body. Your clutch linkage and shifter will need to be adjusted, but easy enough. Also double check your radiator hoses and fan for proper clearance.
I like the s10 body mounts verse the lift, solid 2" GM bodymounts which are a wider base and take the same bolt.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #4 of 34 Old 08-24-2007, 08:16 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
But the springs will affect the brake lines right? Enough to warrant new longer ones?
So you are saying you recommend that I track down some s10 body mounts and use them instead of a regular lift kit?
post #5 of 34 Old 08-24-2007, 08:52 PM
Bard
I have stock lines all around, same drop and length. I think I had to adjust my rear e-brake cables to do it. Easy enough to do.
Yes, find a set on Ebay or something, I saw a complete set for like $60.
Bard is offline
post #6 of 34 Old 08-24-2007, 09:20 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Just curious.. what size tires are you planning to run with the SOA and a 2" BL?.. that kind of lift gets you into "big rubber" territory.. 38"+ rubber.
BESRK is offline
post #7 of 34 Old 08-24-2007, 09:24 PM
supraman1990
supraman1990's Avatar
1980 CJ5
Not to mention a center of gravity higher than some average people are tall. Also, I'd get longer lines, they are only like $100 for insurance on E-bay.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #8 of 34 Old 08-24-2007, 10:58 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
nothing more than 33's, so do I need the bl?
post #9 of 34 Old 08-25-2007, 01:39 AM
T18A
1977 CJ5
T18A is offline
post #10 of 34 Old 08-25-2007, 04:33 AM
jeepskate
Don't even need SOA for 33's...suggest you do some research. Think about COG, epecially with those narrow track axles...
2.5" lift, some HD shackles which will net you another 1/2" and a little trimming will net you enough room for 33's while keeping your COG fairly low without all of the extra that goes into a proper SOA setup. K.I.S.S...
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #11 of 34 Old 08-25-2007, 07:49 AM
Bard
I agree 100% here. If 33's are your max, go the other route, not SOA. You are just asking for more headaches and more work.
on a off note - My SOA will clear the 35" boggers, but do some nasty rubbing when flexed on the trail. Of course my springs are old and need replacing, but I like being called the weeble wooble going right by the stuck YJ's on the trail
Bard is offline
post #12 of 34 Old 08-25-2007, 01:49 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
I am going to start another thread and ask for some pic's of a SOA with a lift. Maybe I just don't understand the height that I will be getting....
post #13 of 34 Old 08-25-2007, 05:12 PM
jeepskate
You're talking on the order of 5"-6" of lift if you don't use worn out springs...playing in 35" tire and above land where a wider track is also adviseable...this is all basic stuff that you'd turn up wihin 5-10 minutes of research...
post #14 of 34 Old 08-25-2007, 05:16 PM
Bard
Just check my gallery, my current one is the blue one, 34's and 35's on saggy stock springs with a 1.5 shackle.
Bard is offline
post #15 of 34 Old 08-25-2007, 07:34 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
Research shows that I can get anywhere between 3-7 inches from the SOA (depending on what thread or google search I use). That really doesn't mean much to a guy who is really building/planning his first non-stock rig and doesn't know what that looks like. I was trying to get a better idea on the geometry changes that would affect my drivetrain or steering. I will stick with the SOA and no bl.
jeep floor rebuild+body support rail+ 1" hockey puck body lift canadianwinter Jeep CJ Forum 46 03-12-2010 12:26 AM
Poll: Keep 35s and Body Lift or Get 33s and no Body Lift? _Kyle_ Jeep CJ Forum 8 12-24-2009 07:12 PM
body mount bushing/body lift???? rnw77cj5 Jeep CJ Forum 6 12-28-2007 08:49 AM
crooked body, stupid body lift k2stew Jeep CJ Forum 11 04-27-2007 10:26 AM
Body Mounts/Body Lift Question CAH Jeep CJ Forum 2 02-12-2005 08:33 AM
