on board air mounting setups - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > on board air mounting setups
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-14-2008, 04:04 PM   #1
mike4089
Where is everyone mounting there on board air compressors and tanks?? Im going to be buying an on board air setup soon and want to get some ideas on where and how to install it..
Thanks!
mike4089 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2008, 05:03 PM   #2
MontanaCJ5
1974 CJ5
I mounted a platform on the inner passenger side fenderwell. No air tank, however.
MontanaCJ5 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2008, 06:11 PM   #3
GPER
1979 CJ7
This is about the best picture I have of mine, I have a 1 gallon air tank mounted under the battery on the fender. There is room for two, one gallon tanks there. That was the rout I was going take, but the one tank does great.
GPER is offline   Reply With Quote Quick reply to this message
Unread 12-14-2008, 06:40 PM   #4
CJhollic
1980 CJ7
Here is mine. A liitle different than most.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline   Reply With Quote Quick reply to this message
Unread 12-14-2008, 10:04 PM   #5
OldSailor
1977 CJ7
I mounted my York compressor vertically in the normal A/C compressor mounting spot (it can also be mounted horizontally). I mounted a 2-1/2-gallon tank under the body just after of where the front seats are.--where the floor goes up several inches for the rear cargo area. Tucks up nicely in there--but I have a 2.5 inch body lift.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline   Reply With Quote Quick reply to this message
Unread 12-14-2008, 10:05 PM   #6
Indy
No back seat, pump and 7g tank in the back.
I'm the only gay eskimo.
Indy is offline   Reply With Quote Quick reply to this message
