On Board Air - Page 5 - JeepForum.com
post #61 of 79 Old 06-13-2011, 12:50 PM
79jeepincj7
1979 CJ7
To bring this back to life. JeepHammer are you saying that to run the pressure lines into your axles and transfer your removing the vents? So when you are pressurizing everything where is the air leaking out from? The seals? And how do they breath and let air out when hot? Certainly not bashing. Just curious to know because I'm going to do the same thing.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #62 of 79 Old 08-01-2011, 10:21 AM
steveojeepster
1978 CJ7
I've scored an AMC York compressor and stock engine mounts for my 258. I've been trolling the threads in search of all the great install information but am stuck on one item. I have the stock flange style fittings on the compressor. I hear that the output line can get quite hot and folks recommend a braided stainless line to dissipate heat. Problem I'm having is trying to determine which line to buy that will accomodate the stock fitting and connect to the coalescing filter. Any guidance would be greatly appreciated. I'll be documenting my install for benefit of the forum and future coverters.
steveojeepster is offline
post #63 of 79 Old 08-01-2011, 12:43 PM
aero mech
aero mech's Avatar
1980 CJ7
You can purchase fittings from Kilby Enterprises that will screw on the top of the compresser. The fittings have 3/4 npt that you can adapt to an AN style braided hose using a 3/4 npt union. Any good hydraulic shop should be able to make on to your spec. JC
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #64 of 79 Old 08-01-2011, 04:06 PM
JeepHammer
Running On Empty...
1973 CJ5
The 70 amp relays are EASY to find, they are all over E-bay and else where.
About all the HID lighting systems on the upscale cars use them,
They are used for power seats, and other stuff all over common cars.
In a pinch, you can walk in and pick out a 'Starter Relay' for a Harley Davidson and they will hand you a 70 amp automotive relay just like the ones I've been advocating for electric compressors.
Hella lighting systems for off road vehicles uses the same 70 amp relay as Harley and most BMW, Lexus, Cadillac and about everything else that uses HID lighting.
The flexible 'Whip' hose from compressor to plumbing system is there to...
1. STOP line breakage because of engine vibration.
Flexible hose doesn't fracture like hard line when connected to a vibration producing mount.
2. To allow the discharge air, which can be close to 200 degrees, to cool some before it hits plastic fittings.
There is plastic/rubber in EVERY swivel fitting, There are tons of fittings with plastic seals & liners, so just because it LOOKS like it's all metal doesn't mean a thing.
Whips run about $20, and for me they are pretty much MANDATORY,
But don't take my word for it, I only do this every day, all day long for a living
Proper DC compressor switches are about $20 each...
I carry three common kinds at work,
On/Off pressures, 90/120, 130/135, and 135/150.
The 90/120 is the most common for vehicle install and it works FLAWLESSLY.
Since most engine driven compressors are going to spit oil, DO NOT expect the 'Pump House' or 'Water Tank' switch to last long.
The oil will rot the seals very quickly, and you are out looking for another $40 or $50 switch in no time.
Plus, they are big and ugly and not rated for DC current switching.
All of which have been problems for us in the past,
So we use a CHEMICAL RATED, DC RATED, Actual COMPRESSOR SWITCH.
Not some 'Monkey Rigged' water pump switch...
DO NOT worry about 120 PSI of air pressure 'BLOWING UP'...
It won't happen, you get a 'Woosh' of air if you puncture the tank and that's about it. No 'Explosion', no 'Shrapnel', none of the horror stories, there simply isn't enough pressure/volume in these little tanks to do the things you hear about...
I've popped a couple of tanks on the trail, so I'd advise keeping away from the 'Shiny' aluminum tanks if you actually wheel your Jeep... they get punctured pretty easily compared to the steel DOT rated tanks.
The best place to get a 'Low Budget' tank is a big truck parts store.
They are heavy gauge steel, rated for a working pressure of 150 PSI, and stress tested to 3 times that amount to pass DOT regulations.
A big truck salvage yard will provide you with all the fittings, hose, tanks, switches, air manifolds, relays, ect. you can carry away for cheap,
And you will find tanks in all shapes, sizes, volumes, mounting arrangments, ect.
Since the 'Average' big truck has about 5 tanks, and the average trailer has 3 tanks, they are EVERYWHERE in a salvage yard...
You will get DOT rated hose, fittings, switches, tanks, ect., Not the 'Made In China' crap a lot of the 'Off Road' places are trying to sell as 'Kits'...
If you go with an engine driven compressor, try to make it a York.
The largest volume compressors York made with a DC clutch was for Ford/Sterling big trucks, and you can find them in International trucks also.
MUCH larger displacement than the Jeep/York most people use in this situation, and the mounting flanges on the big truck compressors are EXACTLY the same as your Jeep brackets...
MAKING your own manifold for your SPECIFIC application can be a good thing.
I saw a guy make an 'Inline' manifold out of a 'Turn Buckle',
Re-threaded the ends for air line fittings,
Drilled/tapped holes in the side for his appliances, and since it was aluminum, it looked nice and dissipated heat quite well.
Another solution is a plain aluminum block. Anything you can find about 1" square bar to about 1" thick and 3" square will make a GREAT manifold.
Since you are working with AIR, The passages do NOT have to line up 'Exactly'...
As long as the air can pass through, it's no big deal, so a hand drill is FINE for the work.
Tapping the holes isn't any big deal once you have done it a couple of times and use good lubrication on the tap...
Just remember to back out/break chips OFTEN, and use the correct size drill bit to begin with...
Hand drill, some drill bits, a hand tap and a vice to hold it in is about all it takes.
If you are working with Aluminum, Copper or Brass/Bronze, just make SURE you use a proper cutting/tapping lubricant and back out/break chips early and often.
This takes NO specialized tools, nothing expensive, and nothing hard to do,
Just time and practice.
DO NOT BUY 'CHEAP' TAPS! Get good CARBON steel taps that are sharp!
Cheap taps will cause problems, and high speed steel taps like to break without warning and are a pain to remove!
You can break a carbon steel tap with a sharp chisel if you break it off in the hole most times...
Carbon steel stays sharp longer, and that is a GOOD THING!
Taps are usually under $20, and some come with the proper size drill for the tap for a few extra bucks if you don't have a good set of properly sized drills...
On Board Air is VERY handy to have,
And the more tank space you have the better off you are!
Two or three small tanks equals one LARGE tank!
This is AIR you are pushing around, so you don't have to worry about fluid flow or anything else, just plum them together anywhere you can get them mounted and they WILL work together....
Most people think they have to run one hose INTO the tank, and a separate hose OUT of the tank to the appliance.
Nothing could be further from the truth!
The same line that feeds the tank can have a 'T' in it for you to use air right off of, or go to a second or third tank... and they will ALL contribute to total volume, and will all equally combine to power anything you want to do...
Air doesn't care where you put it into the tank, take it out of the tank, or combine more than one tank to do the work...
No 'Gravity' feeding like you have to do with liquids, it can all work off ONE line with no issues.
As for the pressurized drive train questions...
Once you have gone through a pressure regulator,
You can pressurize ANYTHING that has a vent in it.
The Differential housings on the axles are a prime example,
So is the transmission/transfer case.
Since EVERY COMPONENT HAS SEALS in it, the excess pressure will escape through those seals...
My axle tubes blow bubbles under water. The pressure isn't excessive enough to blow the seals out,
And SOME air escapes past flaws in the seals.
Those bubbles tell you that you WOULD have had water in the housing because of those flaws in the seals!
My transmission blows bubbles around the shifter arm.
Again, the pressure isn't high enough to dislodge seals,
Yet any escaping air shows you where water WOULD HAVE ENTERED without the pressure...
The problem with the transmission is,
The transmission was TOO LEAKY to pressurize!
People seem surprised to find water in their transmissions after leaving the Jeep out with the top off...
They seem so surprised when I show them you can pour water on the shifter and it runs RIGHT INTO THE TRANSMISSION!
That shifter arm leak is so bad I couldn't keep enough air VOLUME in the system to get pressure.
I had to use an ATV CV joint boot, hose clamp it to the transmission pivot pin mount on the top cover of the transmission,
And run the shifter out the 'Little Hole' in the CV joint boot and clamp that down too...
FINALLY could build/hold the 5 to 7 pounds of pressure I try to run...
My transfer case blows bubbles from around the shifter arms and seals.
Again, same thing.
The pressure isn't high enough to dislodge the seals, yet everywhere you see bubbles, there WOULD HAVE BEEN WATER GETTING IN!
Even my distributor blows bubbles while it's running quite happily SUBMERGED in water....
Positive pressure, even small amounts of positive pressure, will keep water from entering.
I pressurize the distributor cap, differential housings, transmission and transfer case with air pressure.
They blow bubbles instead of filling with water.
Once the compressor is on and the regulator is turned over to the drive train/ignition, I have no issues what so ever driving into water up to my dash...
We often back down into the lake to clean up the vehicle after being in the huge mud pits we have around here.
That mud STINKS, it's corrosive, and it's better washed off the vehicle,
So with my ELECTRIC compressor running (and engine often turned off while we wash things out) we back down into the lake with the water often up to, and sometimes over the hood, and splash around a while.
It's a REAL refresher when it's 105 degrees outside,
And we have NO ISSUES with getting the vehicle started again, or getting water in the axles/transmission/transfer case.
Why do you think I have a thread to the ignition and waterproofing hubs/axles and stuff on my signature?
We like it WET around here!
Compressor inlet is in the windshield frame, WAY up high over the water level, and as long as my WATERTIGHT ELECTRIC COMPRESSOR runs, no water gets into the components where it will do damage...
FLAT FREAKS PEOPLE OUT when they see us out there with water up to the hood and us out splashing around!
Now, before you try this, be advised, I spent quite a bit of time getting the engine water tight!
Snorkel, vents for crankcase, ect...
And you WILL occasionally get water in the fuel tank if you aren't careful and your emissions system is still in place!
That charcoal canister WILL suck in water if you don't see to the issue!
With a SECONDARY distribution block and a regulator, it's not an issue to pressurize everything.
It's simply two valves.
One is the 'Atmosphere' vent that the components normally run on, and you CLOSE that one.
Then you open the pressure valve so the block pressurizes the components from the pressure regulator.
Nothing to it.
When you are done in the lake, mud pits, ect.
You simply turn the air valve 'Off' and turn the vent back 'On'...
Takes longer to dial down the regulator than to waterproof the drive train.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #65 of 79 Old 08-03-2011, 08:44 AM
arctichalo
arctichalo's Avatar
1981 CJ7
Are you speaking of the engine heat building up around the line or heat generated from the compressor?
arctichalo is offline
post #66 of 79 Old 08-03-2011, 10:25 AM
steveojeepster
1978 CJ7
I'm concerned about the heat generated by the compressor, some including Hammer above indicate heat could get in excess of 200 degrees. A flexible whip style hose is preferred but i'm not sure which type of fittings are appropriate. Stock York flange fitting to hose to NPT fitting on coalescing filter. Seems like it might be a custom application but i'm trying to keep costs down.
post #67 of 79 Old 08-03-2011, 10:59 AM
JeepHammer
Running On Empty...
1973 CJ5
The compressor generates it's own heat when it works.
Compressed air sheds a LOT of energy as it compresses, that energy comes off as heat, and a LOT of it!
Walk up and put your hand on a compressor head sometime....
You'll only do that ONCE!
The head is VERY hot, so you want to cool down that compressed air and loose the head heat before you get to 'Melt' parts...
Using ANYTHING that will melt close to the head will get you a leaking system and melted parts...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #68 of 79 Old 08-09-2011, 06:25 AM
steveojeepster
1978 CJ7
I think I read somewhere that an SAE fitting would go on the compressor with an NPT adapter to connect to a stainless steel whip hose. Anyone have any experience with the stock fittings on an AMC York?
post #69 of 79 Old 08-09-2011, 07:01 AM
JeepHammer
Running On Empty...
1973 CJ5
Watch what 'SAE' or 'DOT' fitting you use, many have plastic that aren't rated for the heat the compressor head will generate.
There are compressor specific fittings also.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #70 of 79 Old 10-11-2011, 09:08 AM
steveojeepster
1978 CJ7
Just curious what size air tanks folks are using. I found what looks to be a pretty good deal on a 2.5 gallon tank with some fittings...
http://www.4wheelparts.com/Towing/Sm...56&t_pl=101619
Would that be sufficient to keep the york compressor from having to run constantly while filling tires? Gearing up for the install shortly and appreciate your thoughts. I'll be sure to post some pics when I'm done.
post #71 of 79 Old 04-28-2012, 11:02 PM
CJateME
1981 CJ8
iv only had a small amount of oba experience but ill put it out there for others to follow....
my last yj had a sanden ac compressor in it i believe... i pulled the underdash unit out because it stopped working long before i got the jeep.
i used a normal pancake style air compressor minus the electric motor mounted to the passenger side fender with a 2' whip that i had "twirled" or twisted in a coil fashion to reduce the length to connect it to the tank.
wiring the clutch was easy using the pressure switch that was already on the compressor. i used a toggle on the dash to energize the system then the pressure switch did the on/off switching.
hand throttle mod using parts off a bycicle was mounted (insert ducktaped) to the stick shifter ... it wasnt pretty by no means and but was very functional.
tank was 1 gal. but i kept a lender i made out of an empty 5 gal freon bottle in the back... just one connectoin at the tank but with the engine at 1500 rpm and useing the lender tank i could pull one tire off useing a 1/2 inch impact bfore the the compressor would turn on....
only took a min. to refill then repeat...
i could air all four tires from 16 psi to 30 psi in under 5 min .....
CAUTION: this system had no internal oiling but with a few drops of marvel mystery oil during my normal oil changes and a squirt or two of wd40 if it started sounding funny on the trail, both were put through the inlet side were a small lawn mower filter was hose clamped
it wasn't an elaborate system, or pretty but it lasted me for over 4 years of wheeling nearly every weekend and according to the buddie i sold the heep to its still going strong but he admits he dont use it very much any more just the occasional air up if one is low
I have no special talent. I am only passionately curious.
Albert Einstein
CJateME is offline
post #72 of 79 Old 05-01-2013, 01:11 AM
RedNeckCorvette
1979 CJ7
JeepHammer Great thread and thanks for that. If you get the chance ''for a short time'' and for the full cleansing effect you might remove those fan belts on your rig and go swimming wile in motion. Remember this is like other pleasures most cannot resist it can lead to unexpected complications if prolonged.
Removing fan belts just fording a river or a stream is something I have done for years, always checking or changing fluids soon thereafter. I look forward to the changes.
RedNeckCorvette is offline
post #73 of 79 Old 04-16-2014, 10:12 PM
cjjon7
1983 CJ7
Picked up a york today from nixer here on the forum, and am trying to research whats different about this one vs many others ive seen...first off, its a york 210r...says so on the tag. However, its got a big old 7" pulley and barbed male fittings on top, which doesnt resemble an amc model. I assume the larger pulley will cause less of an output volume than the 6 due to rotational speeds...but im not too worried there. Just want to know what ive got. Ill post a picture in a minute..
cjjon7 is offline
post #74 of 79 Old 04-16-2014, 11:31 PM
billybooster2
1983 CJ8
I have exactly same. I believe they were ford connectors??? Either way a hose and a clamp works fine for input and out...
Sent from under this leak
billybooster2 is offline
post #75 of 79 Old 04-16-2014, 11:43 PM
82JeepCJ7
1982 CJ7
Pull the clutch off the front and look at the end of the crankshaft. It will tell you what stroke your compressor is.
I built mine using a York compressor and stock AC mounts. The air intake is ran up to the air cleaner so I don't have to run an additional filter. The output goes through a check valve, air/water separator, then it feeds a line under the dash to the gauge and cut off switch. The other lead goes to the rear 7 gallon tank and the front output next to the winch. I can air up tires very quickly, run air tools, and it never overheats. I've been using this compressor as OBA since 1998 and its never used a drop of oil.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
on board air
On Board Air You Didn't Know You Had Oily Jeep CJ Forum 19 03-15-2009 09:45 PM
Need help with on board air coyote69 Jeep CJ Forum 6 07-20-2007 04:34 PM
New To The Board Double AA Jeep CJ Forum 2 09-27-2004 07:46 PM
I want On Board Air but... fredrader Jeep CJ Forum 4 09-07-2004 05:45 PM
Help w/ on Board Air set-up steve1244 Jeep CJ Forum 2 03-04-2003 10:49 PM
