Blown head gasket repair with steel seal - JeepForum.com
post #1 of 7 Old 01-06-2010, 07:39 PM Thread Starter
75CJLevi
1975 CJ5
Has any one tried the product steal seal to repair a blown head gasket or something similar? Please I am looking for honest opinions
Thanks,
Rick
1975 CJ5 Levi Edition, 304 V8 AMC; Blue with denim seats.
75CJLevi is offline
post #2 of 7 Old 01-06-2010, 09:23 PM
wrongway92407
wrongway92407's Avatar
I have used K$W Block Seal, I had a 87 yj that the block was creaked on the left side between to the 2 freeze plugs. Ran it fore another 2 years! In fact it's been setting for over 2 years and still has coolant in the radiator.
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #3 of 7 Old 01-07-2010, 12:35 AM
80cj
80cj's Avatar
1980 CJ5
Some of that stuff works but depending on what the problem is. If the head is warped, the correct repair would be to have the head milled flat again.
80cj is offline
post #4 of 7 Old 01-07-2010, 01:09 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I'd think that depending on where the leak is - into a cylinder or just a coolant leak. If it is leaking into/out of the combustion chamber, then a "tune-up-in-a-can" won't work, too much heat and pressure involved. If it is just a head gasket leaking coolant out into the oil or externally, then possibly, since it'd only have the 16psi or whatever the coolant system cap is rated at pushing against the sealer.
Rick
Cutlass327 is offline
post #5 of 7 Old 01-07-2010, 07:34 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You can try to short shift problems like this all you want, but in the end the offending head gasket will let you down, perhaps with catastrophic consequences. Do yourself a favor and and replace it. It will be cheaper in the long run and may save you a long walk.
jeepdaddy2000 is offline
post #6 of 7 Old 01-09-2010, 04:30 PM
afgd1
jeedaddy is right i tryed some of this and now i am replacing engine so do the right job the first time itll save money and time in the long run
afgd1 is offline
post #7 of 7 Old 01-09-2010, 06:48 PM
trillobite
I'd only use it to get my vehicle home. Head gaskets aren't that bad to replace, if you have a garage, time, and tools.
trillobite is offline
Blown Head Gasket? Cpolinsky Jeep CJ Forum 0 01-22-2010 05:22 AM
!!! head gasket blown help!!!!!!! afgd1 Jeep CJ Forum 2 12-23-2009 08:34 AM
cj7 304 v8 blown head gasket thegrand Jeep CJ Forum 2 09-30-2009 08:42 PM
Blown head gasket? again! trueprimitive Jeep CJ Forum 5 09-29-2009 12:30 AM
Blown head gasket on 258 I6? SuB8HaVeN Jeep CJ Forum 7 01-07-2008 02:16 PM
