-   -   Blown head gasket repair with steel seal (http://www.jeepforum.com/forum/f8/blown-head-gasket-repair-steel-seal-942164/)
75CJLevi 01-06-2010 07:39 PM
Has any one tried the product steal seal to repair a blown head gasket or something similar? Please I am looking for honest opinions
Thanks,
Rick
wrongway92407 01-06-2010 09:23 PM
I have used K$W Block Seal, I had a 87 yj that the block was creaked on the left side between to the 2 freeze plugs. Ran it fore another 2 years! In fact it's been setting for over 2 years and still has coolant in the radiator.
80cj 01-07-2010 12:35 AM
Some of that stuff works but depending on what the problem is. If the head is warped, the correct repair would be to have the head milled flat again.
Cutlass327 01-07-2010 01:09 AM
I'd think that depending on where the leak is - into a cylinder or just a coolant leak. If it is leaking into/out of the combustion chamber, then a "tune-up-in-a-can" won't work, too much heat and pressure involved. If it is just a head gasket leaking coolant out into the oil or externally, then possibly, since it'd only have the 16psi or whatever the coolant system cap is rated at pushing against the sealer.
jeepdaddy2000 01-07-2010 07:34 AM
You can try to short shift problems like this all you want, but in the end the offending head gasket will let you down, perhaps with catastrophic consequences. Do yourself a favor and and replace it. It will be cheaper in the long run and may save you a long walk.
afgd1 01-09-2010 04:30 PM
jeedaddy is right i tryed some of this and now i am replacing engine so do the right job the first time itll save money and time in the long run
trillobite 01-09-2010 06:48 PM
I'd only use it to get my vehicle home. Head gaskets aren't that bad to replace, if you have a garage, time, and tools.
The time now is 06:06 AM.
