Blown head gasket? again! - JeepForum.com
post #1 of 6 Old 09-28-2009, 06:25 PM Thread Starter
trueprimitive
I just put a new head gasket on my 4.2 about a month ago and it has run just fine until I was out ridin the other day and stopped, took the oil cap off and what do you know white residue all over the inside of the cap! I drove it home and parked it. Do you guys think the head gasket could just need to be retorqued?
trueprimitive is offline
post #2 of 6 Old 09-28-2009, 06:47 PM
CjinPA
CjinPA's Avatar
Did you have the head checked to see if its warped?
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #3 of 6 Old 09-28-2009, 06:51 PM
Coiz
1979 CJ7
Some of that can occur from condensation and does not automatically mean the head gasket is shot. Crack the oil filter loose and collect the oil in a clean tub to see what it really looks like. The last time it went out what happened, was there oil in the coolant, coolant in the oil or both? Could be residual signs from the first time it happened.
Mike
Coiz is offline
post #4 of 6 Old 09-28-2009, 07:20 PM
KMD
1976 CJ7
+1 solid advice. Does it taste sweet like coolant?
KMD is offline
post #5 of 6 Old 09-28-2009, 09:10 PM Thread Starter
trueprimitive
There was coolant in the oil the first time the gasket went, and no I didnt have the head checked to see if it was warped.
post #6 of 6 Old 09-28-2009, 11:30 PM
Coiz
1979 CJ7
There was probably a lot of residual moisture in the crankcase and block from the first failure. You're likely seeing that condensing on the cap. Like I said, crack the oil filter or drain it all into a clean bucket. If it looks like chocolate milk, you're in trouble. If it looks clean, put it back in and run it. Might not be a bad idea to shorten the interval for the first oil change after the head gasket replacement. Extended full temperature engine runs are the best thing to help burn that off. Short trips typically compound it.
Mike
Coiz is offline
How do I diagnose a blown head gasket? imtheant Jeep CJ Forum 19 11-26-2013 08:34 AM
Blown Head Gasket? Cpolinsky Jeep CJ Forum 0 01-22-2010 04:22 AM
!!! head gasket blown help!!!!!!! afgd1 Jeep CJ Forum 2 12-23-2009 07:34 AM
cj7 304 v8 blown head gasket thegrand Jeep CJ Forum 2 09-30-2009 07:42 PM
Blown head gasket on 258 I6? SuB8HaVeN Jeep CJ Forum 7 01-07-2008 01:16 PM
