Blown fuse issues - JeepForum.com
post #1 of 16 Old 03-30-2014, 05:07 PM Thread Starter
Booger1
1981 CJ7
Blown fuse issues
I keep blowing my IGN LPS fuse when I have my sound system hooked up. Pioneer head unit with amp and sub. Also the head unit will operate with the ground unhooked. Anyone want to tackle this one??
Booger1 is offline
post #2 of 16 Old 03-30-2014, 07:31 PM
texasdave
texasdave's Avatar
1980 CJ7
You have a direct short a bare wire or connection grounding and blowing the fuse. Or it is wired incorrectly which is why it works without a GROUND.
texasdave is offline
post #3 of 16 Old 03-30-2014, 08:44 PM
BagusJeep
1981 CJ7
You do not have it hooked up to the Radio socket on the Fuse Box. This outlet is powered by the ACCY fuse. Instead you have it hooked somehow to the IGNLPS feed which goes to the instrument cluster etc. I suggest you go and look at where it is wired and, if you have the original fuse box, consider hooking it into the panel properly. It may be that your sound gear is far more powerful than AMC engineers realised in the 1960s when the electrical system was designed so that 10 Amp ACCY fuse may not be enough.
As to the ground issue, you may have an extraneus ground through the case of the head unit. This is not desirable as it will probably be a dirty ground and drawing too much amperage. I suggest you look at the grounding overall on the panel and whether a seperate ground system would be a good investment. Old CJs ground through the steel bodywork (aka rust) so a dedicated wired ground system back to the battery can cure such issues.
I attach various pics. They are a mish mash of early 80s fuse box data (the 1984 diagram is applicable but of course a 1980 does not have electronic engine control) and illustrate the point about where you should be connecting the stereo. You may only have a cigar lighter on the ACCY circuit, maybe not, but the stero should be attached here so it is available with the key in ACCY and RUN. At the moment it may be availbel in RUN and START but not ACCY. If you have it availabel in ACCY you can listen to the vibes without the ignition on, a good idea as the ICM can cook in 5 minutes in RUn without the engine running.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 16 Old 03-30-2014, 09:25 PM
LumpyGrits
That's only a 3 amp circuit.
You need to run a dedicated circuit.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 16 Old 03-31-2014, 01:50 AM
BagusJeep
1981 CJ7
Yep, I wonder how much all that stuff needs?? If it is a lot then it will need a seperate power supply depending on wire sizes. Tapping off the solenoid into a fusible link and then a fuse would be a good starting point, then ground back to a common ground point.
You are right LG, the IGNLPS circuit was smaller in the early 80s, it was enlarged when the computer was added as the diagrams show.
My radio only needs more than 2 Amps when it has water inside.
post #6 of 16 Old 03-31-2014, 05:26 AM
Mike Romain
I have never seen a stereo and amp, let alone a sub that would run off the stock Jeep fuse panel. The one in my YJ has cables the size of my little finger (4ga?)with 60a fuses direct to the battery. The one in my CJ uses 10 ga cable fused at the battery posts.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline
post #7 of 16 Old 03-31-2014, 06:14 AM Thread Starter
Booger1
1981 CJ7
The radio is wired to the radio output on the fuse box so that's the part that makes no sense to me. The amp gets direct feed from the battery.
Booger1 is offline
post #8 of 16 Old 03-31-2014, 06:24 AM
Mike Romain
Ground issues stealing the 'ground feed' thought the light circuit would be my next guess. You likely have the stereo wired to light up right?
Mike
post #9 of 16 Old 03-31-2014, 06:45 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Do you have constant power hooked up to the head for the clock and memory?
Matt1981CJ7 is offline
post #10 of 16 Old 03-31-2014, 11:45 AM Thread Starter
Booger1
1981 CJ7
Yes it does
Booger1 is offline
post #11 of 16 Old 03-31-2014, 11:46 AM Thread Starter
Booger1
1981 CJ7
Seems like that wire goes directly to the battery tho.
Booger1 is offline
post #12 of 16 Old 03-31-2014, 11:59 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Total wild guess.
I hooked up a radio once and got the ground and dash light feed mixed up. Radio played, it was using the dash lights for the ground path. What tipped me off as to my error was the volume and intensity of the song being played, the dash lights glowed brighter or dimmed with the same intensity. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #13 of 16 Old 03-31-2014, 12:04 PM
Mike Romain
Originally Posted by Jon In Tucson View Post
Total wild guess.
Jon In Tucson
He does say it works with no ground connected......
Mike
post #14 of 16 Old 03-31-2014, 12:11 PM Thread Starter
Booger1
1981 CJ7
Yes it's getting ground from somewhere. I guess this evening I'll pull it out and make sure it's not grounding through the case. If it still plays I guess I'll start disconnecting wires one at a time till I find it.
Booger1 is offline
post #15 of 16 Old 03-31-2014, 12:18 PM
Mike Romain
Confused. Why would you not want the case grounded? Then you would have to tie the speaker grounds to the body or something to ground the unit or it will steal a ground through the lamp circuit. If the unit has a dedicated ground wire, that should go to the battery. The tub is not a good clean ground source.
Mike
