block to bellhousing sleeves - JeepForum.com
post #1 of 23 Old 01-10-2012, 12:18 PM Thread Starter
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
on the 3 and 9 o'clock positions on the back on the amc v8 blocks their are 2 sleeves that stick out of the block to align the tranny with and bolt through. does anyone know if these are necessary? and if so, where can i get new ones?
ive been searching for a while and cant find a thing. thanks in advance!
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #2 of 23 Old 01-10-2012, 12:22 PM
only in a jeep cj
Yes, they are needed as the properly align the bellhousing to the block as there is some movement in just relying on the bolt holes. This centers the clutch and inputshaft as well. Yes, you need them. The 6 cyl engines use them too so good used ones are out there or in a pinch a correct section of cut steel tubing would work too.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 23 Old 01-10-2012, 12:24 PM
roadhog304
1973 CJ5
yes you really do need them to help align the block to the bellhousing. try looking at a engine machine shop. maybe they can get some for you.
roadhog304 is offline
post #4 of 23 Old 01-10-2012, 12:27 PM Thread Starter
RobsCrawlin7
no balls
****, i knew that was gonna be the answer lol. its all that is holding us up from putting this 360 in my buddies cj.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #5 of 23 Old 01-10-2012, 06:25 PM
mopar346
Just for the sake of knowledge does anyone know if they are AMC specific or if other engines used the same ID and OD alignment pins?
Careful your character's showing
mopar346 is offline
post #6 of 23 Old 01-10-2012, 07:35 PM
82JeepCJ7
1982 CJ7
They are called Dowel pins. Places like NAPA will have them in stock.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 23 Old 01-10-2012, 08:50 PM
jeepdriver54
1978 CJ7
Covered in detail at Novak Adapters: http://www.novak-adapt.com/knowledge/clutches_etc.htm
out
jeepdriver54 is offline
post #8 of 23 Old 01-11-2012, 01:12 AM
86cj74.2L
86cj74.2L's Avatar
I got my at the dealer for the I6
Without it it will crack flex plates and starter won't be aligned properly.
86cj74.2L is offline
post #9 of 23 Old 01-11-2012, 02:38 PM
agear
Interesting............... My b.i.l. told me they were there just to speed up assembly on the assembly line. With no jeep body on, they can take the bellhousing,transmission,transfercase as one unit and guide it on the dowels. I guess he was wrong. I'm trying to remember if the bolt that goes from bellhousing to block was a snug fit in the hole in the bellhousing.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #10 of 23 Old 01-11-2012, 03:25 PM
82JeepCJ7
1982 CJ7
There is too much slop in the bellhousing bolts. With out the dowel pins, the bellhousing could rotate a few degrees either way, as well as up/down/left/right. The dowel pins are a snug fit and keep everything aligned.
post #11 of 23 Old 01-11-2012, 11:06 PM
86cj74.2L
86cj74.2L's Avatar
it wont move up and down much because of the hole in the back of the crank. The TC on the automatic fits in the crank but it will rock side to side.
I know this......2 flexplates and 1 starter. all because of the dowel pins not in the long block I bought. (jerks never put the oil bypass unit on block also just spun the filter mount in block, also used the harmonic balancer washer for the cam gear washer with Chevy orange paint on it instead of the special one slotted to oil the cam chain....glad they went out of business! They were from York, PA.)
When a flex plate cracks it sounds like a rod knock.
To install the dowels I removed the rad, removed the bell-housing and TC bolts, Fuel line etc.....
Undid the motor mount bolts and pulled the engine forward enough to push to pins in then slipped it all back together.
post #12 of 23 Old 01-25-2012, 08:31 AM Thread Starter
RobsCrawlin7
no balls
so let me make sure i understand this. those dowel pins replace the stock bolt and sleeve on the 9 and 3 o clock positions on the bellhousing leaving the top 2 or 3 bolts (cent remember how many) left to hold the motor and bellhousing together? sounds wrong.
also, we are having one hell of a time aligning the pilot bushing and clutch onto the input shaft of the tranny. any ideas?
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #13 of 23 Old 01-25-2012, 08:41 AM
Pathkiller
1974 CJ5
Wrong. What you are calling a "sleeve" is correctly called a dowel pin. It is hollow and has a bolt through it.
Pathkiller is offline
post #14 of 23 Old 01-25-2012, 02:42 PM
fredrok
http://www.americanpartsdepot.com/engmisc.htm#dowels
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #15 of 23 Old 01-25-2012, 03:28 PM
82JeepCJ7
1982 CJ7
Yup.
T176 bellhousing same as T5 bellhousing ? agear Jeep CJ Forum 39 09-27-2011 07:52 PM
Looking for threaded sleeves........HELP!!! Wossi Jeep CJ Forum 7 07-28-2011 11:56 AM
bushing sleeves...or not? rbunch4468 Jeep CJ Forum 3 03-22-2010 09:57 AM
Bellhousing for GM151 block 149 cpmarshalljr Jeep CJ Forum 1 02-14-2010 06:47 PM
shackles have sleeves? 85cjbeater Jeep CJ Forum 4 10-25-2007 01:13 PM
