10-06-2006, 12:37 PM
#1
I have an air pocket in my proportioning valve and after completly bleeding the brakes I cant get it out. I heard there is a tool used on the proportioning valve to fix this while bleeding. Anyone familiar with this or where I could purchase such a tool? 79 CJ7 Thanks
10-06-2006, 12:51 PM
#2
Parts locator
The tool is used to hold the pin on the front of the valve in. I don't know where you would get one but I suppose a big "C" clamp would also do the trick.
84 CJ7 Northstar V8 Pictures of it,
http://s56.photobucket.com/albums/g1...nds/?start=all
91 YJ Renegade, I have owned it since it was new.
97 TJ daily driver.
2011 F250 King Ranch.
Jeeps that I am currently parting out;
1994 Jeep YJ 6cyl 5spd
1994 Jeep YJ 6cyl auto
1993 Sahara Jeep YJ 6cyl auto
1989 Jeep YJ 4cyl 5spd
Just my luck
I was born in the land of plenty now there ain't enough.
10-06-2006, 12:55 PM
#3
There is such a tool but I have never been able to find it except on the MAC tool truck, which means it's pretty $$$. I have found that if you have a buddy push on the brake pedal, you can use a small pair of vise grips and gently grab the proportioning valve nipple (it will pop out with pressure applied to the brakes) and hold it out while you bleed the brakes.
I also use this trick for bleeding and have yet to find a brake system that we couldn’t get all the air out of…Take a 1’ or 2’ft rubber hose that fits very snug over the break bleed fitting, and plug or cap off one end of it. Then make about a 1” slit in the hose just above the plug and dip it into a bottle of brake fluid with enough fluid to cover the slit in the hose. What this does is gives the brake system a little pressure while you bleed, and helps force more of the air bubbles down the line quicker. Also the slit in the hose only allows fluid out and reduces the chance of air into the system.
Hope this helps and good luck!
Scott
95 Wrangler, F/I Chevy 350w/auto/ 4-1Lomax Dana 300 transfer case, Dana 60 frt w/ARB and 14 bolt rear w/Detroit locker, shod w/ 42" Swampers, coilovers on all 4 corners
90 Wrangler, Chevy 350w/auto, Dana 300, Dana 44’s frt/rear w/Detroit lockers and 36” Swampers. 1.5 RE lift sprung over.
82 CJ-7, AMC 360 w/Holley Projection/ Ford T-18 with Dana 300, Dana 60 frt and 14 bolt rear w/Detroit locker tires and rims and lift to be determined.
#4
Well its a brand new proportioning valve and has a rubber grommet/cap over that pin of which you speak. It that supposed to be there for that purpose?
10-06-2006, 12:58 PM
#5
You should be able to take the rubber cap off
10-06-2006, 06:26 PM
#6
Is the pin supposed to stay out or in the valve? thanks again
10-06-2006, 07:06 PM
#7
Depends on the valve. I believe on the Jeeps it gets pulled out for bleeding
10-07-2006, 04:53 PM
#8
So did you get them bleed????
scott
10-07-2006, 08:42 PM
#9
I've got a master cyl replacement job coming up. That'll mean bleeding the brakes. What the hell is a "proportioning valve"?
10-08-2006, 06:20 AM
#10
Parts locator
This is a proportioning valve. It is on the frame rail almost right under your brake booster and mc. This is where the lines from the master cylinder run to. It controls the difference in brake line pressure between the front and rear bakes.
97 TJ daily driver.
Just my luck
10-08-2006, 08:37 PM
#11
I've got a '73. I haven't seen anything that looks like the valve pictured. In the pic I have here the lines are one for the front, and one for the rear. Are prop valves for newer Jeeps?
10-09-2006, 06:02 AM
#12
Parts locator
The valve in the pic is for 82 to 86 CJ's. I am not sure if there is a valve on the 73. Don't take this wrong, but if you would fill in you profile (jeep specs) it would help in the future with responces to your questions.
97 TJ daily driver.
Just my luck
10-12-2006, 01:03 PM
#13
If it has drum brakes on all 4 corners it won't have one. If it has disc brakes on the front and drums on the rear it shouldl be down there somewhere
10-12-2006, 02:49 PM
#14
It's down lower then the master, it's on the frame under you butt.
Did you try reverse bleeding? That is taking the Wheel cylinders and pushing them in. Then doing the same with teh front Calipers or Wheel cylinders. this pushes the fluid up into the Master cylinder reservoir along with the air bubbles.
MAke sure the Master is not full to the top so the fluid has a place to go.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
