bleeding brakes - JeepForum.com
post #1 of 3 Old 10-22-2002, 02:10 PM Thread Starter
KG4PAM
bleeding brakes
how do i bleed the brakes? i read in my manuals that there is supposed to be some sort of tool attached to the combination valve that you use to pull some sort of valve, or something along those lines. there is no such thing on my combo valve. the reason i ask this is that i have a spongy brake pedal. i suspect that part of the problem may be resulting from my patching a brake line with duct tape a while back, when i put new front pads/shoes on. the hose looked kinda worn, so i put some duct tape around it to extend its life. i got new hoses yesterday, so thati can replace them and then bleed the brakes. thanks for any help you can provide! jairus
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #2 of 3 Old 10-22-2002, 02:24 PM
55-willys
ive always had someone pump the brakes, hold the pedal to the floor, then crack the bleeder on the backing plate, let the person push the pedal to the floor, close the bleeder valve, and start over again until no air comes out of that bleeder. not sure of the order but your manual should tell you, left rear, right rear and so on.
paul
55-willys is offline
post #3 of 3 Old 10-23-2002, 04:34 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
KG4PAM,
I've always done it the way 55-willys has stated that is until I had to do my last brake job, I took it to the shop, ha ha, NOT. I got a brake bleeder tool/kit from Auto Zone, it attaches to the bleeder valve, you open the valve with the Master Cylinder full of fluid and pump the lever on the tool and bingo the brakes are done.
Make sure you pump until there is no more air being pumped out and make sure you check the fluid in the Master Cylinder often.
One caliper took a couple of tries until it worked.
Also, buy a good bleeding tool, I got the cheap one and it leaked air and was a little hard to determine if it was bled out.
Good Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
Bleeding Brakes Mike78cj7 Jeep CJ Forum 1 11-21-2008 07:08 PM
Bleeding Brakes... 79jeepguy Jeep CJ Forum 13 10-12-2006 02:49 PM
Bleeding My Brakes dreski1 Jeep CJ Forum 1 09-06-2006 08:00 PM
bleeding brakes rmballou Jeep CJ Forum 14 03-09-2006 09:41 AM
Bleeding brakes Spencer77 Jeep CJ Forum 2 01-05-2006 05:46 AM
