Bleed Power Steering Help - JeepForum.com
post #1 of 2 Old 03-18-2003, 11:30 AM Thread Starter
DaRaidz
I had to replace the hoses on my '86 CJ7 power steering last weekend and went through the process I had heard that would bleed the air from the lines....Jack up the front wheels and then with the Jeep running, I turned the wheels back and forth and added fluid. Seemed to do just fine while jacked up, then I took it wheelin on Saturday and ran for several hours. The power steering does not work like it used to on full turns. Going straight and minor turning works great, but full hard turns is still very hard. It seems to not take any more fluid and is not foaming like it's ridding itself of any more air in the lines. Almost like it is vapor locked in the lines. I had heard that driving it around for 20-30 will take care of it, but it hasn't seemed to help yet. Any ideas?
'86 CJ7 I-6, 5 speed, 33 Pro Comp, BDS lift, CD, Hardtop and Doors, 4X Dr. Rockers, 4.88 gears, ARB Air Lockers front and rear, Dana 44 rear, 63K original miles...very sweet rig.
DaRaidz is offline
post #2 of 2 Old 03-18-2003, 07:56 PM
2tall79
Lightbulb
Check out this site, chapter 4.
http://www.agrperformance.com/103/InstallationWeb.pdf
79 CJ-5, 304, T-18A, 4" Pro-Comp lift, 33x12.50x15 BFG MT's, Superior one-piece, LockRights front and rear, Warn 8000#, 6-point cage
2tall79 is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 11:13 AM
Steering issue...Power Steering seems too good!! 76CJ5NGA Jeep CJ Forum 12 05-25-2009 09:48 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 09:01 PM
Can I use manual steering brackets with power steering box? Mud Machine Jeep CJ Forum 2 12-27-2005 10:26 PM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 09:18 AM
