Blazer Heater Mod Help!? - JeepForum.com
post #1 of 6 Old 10-04-2011, 05:50 PM Thread Starter
batmn77
1982 CJ7
I put the upgraded heater motor in the jeep. Hooked everything up and I get nothing when I turn the fan switch on. The only thing that happens when I turn it on is that the volt meter drops down to like 10 volts, and then when I turn it on high it drops to all the way and if I keep the switch on the fuse eventually blows. The motor is not turning on. I ran a wire from the motor straight to the battery to see if it would turn on and it did not. The 12ga jumper wire got extremely hot.
They Cant Stop Me, Even If They Stopped Me.
Car History from 1st to Present:
-1997 Mustang V6 (Sold); -1999 Chevrolet Blazer (Sold); -2001 Chevrolet Silverado Z71 (Sold); -1999 Chevrolet Z28 Camaro; 1982 Jeep CJ-7
batmn77 is offline
post #2 of 6 Old 10-04-2011, 05:56 PM
gojeepin
1983 CJ7
Did you get the motor with the right shaft length? There are two that look the same but the shaft on one of them is longer. Your squirrel cage may be stuck on the housing.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 6 Old 10-04-2011, 06:03 PM Thread Starter
batmn77
1982 CJ7
i bought the pm102. that's what i was told to use for a jeep with a factory a/c.
batmn77 is offline
post #4 of 6 Old 10-04-2011, 06:19 PM
chet44
Sounds like your squirrel cage is binding. I had to put mine in twice for that.
chet44 is offline
post #5 of 6 Old 10-04-2011, 08:20 PM
gojeepin
1983 CJ7
Some members have found out the hard way that the model PM102 is sometimes mislabeled or just a variant is put in the wrong box.
Does the squirrel cage spin freely by hand?
gojeepin is offline
post #6 of 6 Old 10-05-2011, 03:24 AM
Erik719
1983 CJ7
So what is the correct length of the shaft?
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
Blazer heater motor upgrade fastas69 Jeep CJ Forum 35 07-06-2013 03:13 PM
Blazer heater motor upgrade!! husker26 Jeep CJ Forum 21 05-20-2012 06:03 PM
Blazer Heater Motor for '81 CJ5. DHKRIEG Jeep CJ Forum 6 03-30-2011 08:39 AM
Blazer Heater Upgrade Installed...One word of advice. CoastieCJ Jeep CJ Forum 31 12-26-2010 07:54 PM
Just did the Blazer heater motor upgrade - no heat PortlandCJ76 Jeep CJ Forum 13 12-31-2007 05:18 AM
