Blasted pinging was NOT my engine... - JeepForum.com
post #1 of 49 Old 10-20-2013, 09:49 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
...unless the (used) engine I just put in has the exact same problem - knocking under load. (reference my previous thread http://www.jeepforum.com/forum/f8/he...nging-1519237/ ).
I finally got the Jeep out on the road and it's still making the same knock, under same conditions.
My first thought was the tranny (TH400), so I started researching that.
From there I saw mentions of cracked flex plates (I reused my old one), busted driveshaft yokes, Tcase chain slipping, and others.
Now my question is, where do I start looking, now that the engine is out of the equation?
2Xtreme is offline
post #2 of 49 Old 10-20-2013, 10:50 AM
Dougyfreshh
Does the motor have an egr valve if so check if its operating properly if it is maybe the passage way under egr is clogged or maybe the motor is Outa timing
Dougyfreshh is offline
post #3 of 49 Old 10-20-2013, 11:03 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
No EGR valve.
Quite sure it's not engine related.
Wheel, Fix, repeatů.
2Xtreme is offline
post #4 of 49 Old 10-20-2013, 11:19 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
2X,
Damn that's to bad.
Is the knocking always under load? If so, when was the last time you checked the u-joints?
Matt
Matt1981CJ7 is offline
post #5 of 49 Old 10-20-2013, 11:23 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by Matt1981CJ7
2X, Damn that's to bad. Is the knocking always under load? If so, when was the last time you checked the u-joints? Matt
You have no idea how defeated I felt when it started....
Always under load, but never in first...
2Xtreme is offline
post #6 of 49 Old 10-20-2013, 12:09 PM
WindKnot
1977 CJ7
Has anyone asked what grade of gas you're burning? My 258 will accept nothing less than mid grade, and the more octane, the happier my selfish beast is.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 49 Old 10-20-2013, 12:15 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Quite sure it's NOT engine related....
2Xtreme is offline
post #8 of 49 Old 10-20-2013, 12:26 PM
motiv8ya
1979 CJ7
I had that once on my first 79' Cj7 with the th400, turned out to be a loose flex plate bolt that was contacting the inspection cover.
motiv8ya is offline
post #9 of 49 Old 10-20-2013, 01:26 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Wouldn't that be constant, load or no load?
2Xtreme is offline
post #10 of 49 Old 10-20-2013, 04:23 PM
chris989604
1980 CJ7
Mcleod clutch
I installed a Mcleod clutch behind my V8 and the thing was a few thousandth to large and would drag on disc and just barely put paint on the bell housing. If your thrust bearing is worn a little maybe it could be walking back and tapping the housing or pressure plate bolts to long??? Is it RPM related or more relative to the drive shaft RPM?
I had a 327 with a bad thrust plate but it walked forward more than back. Anyway, I installed a Luke clutch and never had another problem.
It is a long shot,
CHris
chris989604 is offline
post #11 of 49 Old 10-20-2013, 06:10 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by chris989604
...It is a long shot, CHris
VERY long shot, considering the TH400 is an AUTOMATIC transmission....
2Xtreme is offline
post #12 of 49 Old 10-20-2013, 06:27 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
If it's doing it only under load perhaps it's contacting something that only occurs when the engine flexes on the mounts under torque.. What shape were the motor mounts in when you swapped the engine?
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #13 of 49 Old 10-20-2013, 07:47 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Less than 1000 miles.....
2Xtreme is offline
post #14 of 49 Old 10-20-2013, 08:01 PM
lucdog
lucdog's Avatar
1980 CJ5
The inspection cover that gets removed to take the torque converter bolts off the flexplate. Remove the cover, see what happnens. Mine would rub under load.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #15 of 49 Old 10-20-2013, 10:31 PM
motiv8ya
1979 CJ7
Mine happened under load, don't know why it was so pronounced under load and not when idling but removing and reinstalling each bolt with some loc-tite fixed it.
motiv8ya is offline
