Black smoke from exhaust ,Why? (video) - JeepForum.com
post #1 of 7 Old 01-26-2010, 02:47 PM Thread Starter
redcj576
1979 CJ7
Right about 00:21 , black smoke comes from the left exhaust. Why? is there maybe a problem with the engine or carb adjustments?
After 00:15 Jeep is in 1st gear ,close to full throttle..
thank you
CJ5 Project finally finished...
'77 CJ7 -.GM 305,T176,4.10s,37x14.5 Creepy Crawlers
'79 CJ7- 350,TH400,NP205,4.88s,39.5" Creepy Crawlers
'61 Chevy Apache 10-all stock
'90 Chevy K1500 4x4 Truck-LT265/75R16 BFG All terrains
redcj576 is offline
post #2 of 7 Old 01-26-2010, 07:12 PM
kjhibbs
1981 CJ8
i am guessing you have not had any replies because the smoke really is not visible. i could not see it at all. have you experienced it otherwise? black smoke is typically oil.
1981 Scrambler; Vortec 4.3 / 4l60e swap; 35s; getting close!
kjhibbs is offline
post #3 of 7 Old 01-26-2010, 07:17 PM
BinghamtonCJ5
1978 CJ5
I would second kjhibbs on both points, I cant see the black smoke either and black is an allmost absolute sign of burning oil.
BinghamtonCJ5 is offline
post #4 of 7 Old 01-26-2010, 07:19 PM
fredrok
Incorrect. Black smoke is fuel burning and indicates a rich mixture. Blue smoke would indicate oil.
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #5 of 7 Old 01-26-2010, 07:23 PM
kjhibbs
1981 CJ8
good call, fredrok is right, it is fuel. check your mixture screws, and your air filter. the video does not help though, any other info would be great.
kjhibbs is offline
post #6 of 7 Old 01-26-2010, 07:29 PM
BinghamtonCJ5
1978 CJ5
I will go with you Fredrok, I have been lucky to have only had a few vehicles that ended with oil burning problems and it allways looked like black or gray smoke to me but I am color blind too, so I will go with you.
post #7 of 7 Old 01-26-2010, 07:30 PM
fredrok
Can't tell **** from the video, but if you guys are at a higher elevation than you have the engine tuned for, it's going to run fat.
d i c k got censored??? What if my name was D i c k?
fredrok is offline
Black Smoke powermacj7 Jeep CJ Forum 6 09-26-2009 07:31 AM
weber 34/34 black smoke android7105 Jeep CJ Forum 2 06-07-2009 09:51 AM
Black Smoke when starting zachblamercj7 Jeep CJ Forum 2 03-28-2009 10:55 PM
Black smoke is bad right? White92 Jeep CJ Forum 12 03-12-2008 04:41 PM
84 CJ7 150 4cyl with black smoke onesourcemike Jeep CJ Forum 3 05-19-2006 09:18 AM
