Bit of a design quandary... - JeepForum.com
post #1 of 19 Old 03-22-2015, 07:37 PM Thread Starter
ikidd
I have a 76 CJ7 with the Quadratrac. Consequently, the diffs are both passenger side. I also have a 350 SBC Gen 1 ready to pull. I wanted to go to a manual transmission, not anything super crawler, but a little more ratio than the TH400 offers obviously.
I would obviously like to bolt up on the transmission, and I'm not doing a lot of lift, so I was worried a NV4500 would be too tall. I was leaning to a SM420 if I can locate one, or a SM465.
I'm looking for some thoughts about which way to go here. I'm open to dropping the tcase for something else, but I want to keep the stock narrowtrack, and other than changing the front and rear axles, I think I'm stuck with the QT or a D18 (not sure if there's a huge advantage to changing to that). But I have to keep in mind how to adapt whatever transmission to either the QT tcase or deal with passenger pumpkins if I get another tcase altogether. I don't see any right/right GM tcases.
I don't need a rockcrawler, but I'd like to get a drivetrain that isn't horrendous by the time I'm done. BTW, I'll be putting in 1 piece axles once I make up my mind on this.
Appreciate any responses to help me get out of my stall here.
1998 ZJ 5.9 - 4", NP242
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
1994 ZJ 4.0 "Rammy" RIP
ikidd is offline
post #2 of 19 Old 03-22-2015, 07:42 PM
y2k-fxst
1964 CJ6
If it was me, even though it will add to the cost of your build, I would go with a narrowed Ford 9" rear axle. Then keep the rest of the drive line (motor, trans, transfer case) GM. If nothing else it will keep parts scrounging easier, also what you will spend for adapters to mate your Quadratrac transfer case to a GM overdrive trans will help offset the cost of narrowing the axle. And you will automatically end up with better inner axles.
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #3 of 19 Old 03-22-2015, 07:52 PM Thread Starter
ikidd
Then I end up with an issue on both axles, because passenger front as well. I could try to find a D300 and go with a narrowtrack D44 from a 72-75 (again find that). The axles seem like the stumbling block either way. Trying to find ones that match a GM is as hard as finding a tcase that matches the axles.
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
ikidd is offline
post #4 of 19 Old 03-22-2015, 07:58 PM
TIPPEDITOVER
At the Mall
TIPPEDITOVER's Avatar
1978 CJ5
Sell it and buy one that has what you want. You will be money ahead as well as saved a boatload of time searching, swapping, ect.
TIPPEDITOVER is offline
post #5 of 19 Old 03-22-2015, 09:18 PM
y2k-fxst
1964 CJ6
Chevy NP203 or NP205 should be available in passenger (got my left and right corrected) side drop front with centered rear.
y2k-fxst is offline
post #6 of 19 Old 03-23-2015, 01:12 AM
TIPPEDITOVER
At the Mall
1978 CJ5
Chevy NP203 or NP205 should be available in drivers side drop front with centered rear.
You mean pass drop right?
post #7 of 19 Old 03-23-2015, 02:22 AM
Pathkiller
1974 CJ5
The simple question that springs to mind is why do you want to swap what you've already got? The easiest solution is to keep your original drive train intact. If your CJ7 is intact and running you'd be far better off selling or trading it for one with a drive train that is more similar to what you want.
Pathkiller is offline
post #8 of 19 Old 03-23-2015, 06:45 AM
colojeepguy
1970 CJ5
How about a Dana 44 out of a CJ?
72-75 had 1 piece 30 spline axles, plenty strong for your application, and all kinds of gear & locker options are made for it.
Then use the 4 speed of your choice adapted to a Dana 20 or Dana 300 tcase.
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline
post #9 of 19 Old 03-23-2015, 10:50 AM
y2k-fxst
1964 CJ6
Yep
y2k-fxst is offline
post #10 of 19 Old 03-23-2015, 11:17 AM Thread Starter
ikidd
304 is blowing exhaust out into the coolant and overheating quickly. I'm not really interested in rebuilding a carbed engine with low power and poor mileage. I also want a manual Xmission so sticking to a GM powertrain seems wise.
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
ikidd is offline
post #11 of 19 Old 03-23-2015, 11:21 AM Thread Starter
ikidd
Not sure why I thought they were all driver side drop, but I see the GMs were passenger. That gets me around 1 axle change at least, probably to the narrowtrack 44 to keep the width. I was kinda resigned to this, frankly, unless I can get an adapter for the QT.
The 205 seems most interesting, since it can be converted to 2-stick. Again, I'm not rockcrawling this so the poor low ratio doesn't bother me.
It looks like these were typically with SM465s pre 85. I haven't looked too far into mating the 465 to something relatively new like the 98 350 SBC from a K2500 I'm using. What do you do with the ECM if it's used to seeing a 4L60E mated up, does it need a flash?
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
ikidd is offline
post #12 of 19 Old 03-23-2015, 12:32 PM
y2k-fxst
1964 CJ6
Ford was the only one that has always been driver's side drop that I know of.
y2k-fxst is offline
post #13 of 19 Old 03-23-2015, 12:42 PM
y2k-fxst
1964 CJ6
Only problem might be actually finding a narrow track 44, then you will still have to upgrade to 1 piece axles if you want strength. Still think the narrowed Ford 9" will end up cheaper.
The 205 seems most interesting, since it can be converted to 2-stick. Again, I'm not rock crawling this so the poor low ratio doesn't bother me.
Would probably have to either get a custom harness, or a stand-alone engine controller.
y2k-fxst is offline
post #14 of 19 Old 03-23-2015, 02:03 PM
Pathkiller
1974 CJ5
Only problem might be actually finding a narrow track 44, then you will still have to upgrade to 1 piece axles if you want strength. Still thing the narrowed Ford 9" will end up cheaper.
?? The 72-75 version has one piece 30-splined flanged axles. No need to upgrade anything. These are not the earlier 19-splined axles you're thinking of. They are also used in postal Jeeps, and thus are quite common.
post #15 of 19 Old 03-23-2015, 03:57 PM
CSP
'72-73 Commandos also had this D44 axle and the spring perches are correct position to make them a bolt in for '76 and up CJs.
CSP is offline
