Billy G's, YJ to CJ conversion, Trips and General BS - Page 55 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Billy G's, YJ to CJ conversion, Trips and General BS
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCCOR is your 1 stop source for everything Jeep!
Unread 06-07-2012, 11:38 AM   #811
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by rmappelt
I've been lurking for some time and really enjoy reading your thread! If you haven't seen it, jscherb has a nice write up on CJ door repair which includes removing the glass here.
Cool, thanks for the link
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 06-07-2012, 12:37 PM   #812
lucdog
lucdog's Avatar
1980 CJ5
Jeep smilly test
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-12-2012, 11:24 AM   #813
lucdog
lucdog's Avatar
1980 CJ5
The problem,
Clip on air chuck doesn't go on far enough , resulting in not enough air or none at all going in the tire. Not a big deal when adding a couple pounds. However when airing up from trail pressures, ( from 4 to 7, up to in the 20's ) this can be a pain, and take awhile. Yes, I could just hold it on, but I'm lazy, and it still takes time to fill a 36/13.50/15 tire x4.
As seen in the picture, the valve stem won't go on far enough.
These are the 3 parts we're working with.
The solution.
The new 90 degree adapter. It has a thinner shank to go further into the chuck. I bought 2 of them at a camping store for $11.
I wouldn't use the adapters on the trail, for fear of sticks getting in and pulling the rubber stem out.
I do use this on the trail, but it still requires bending down, it's hard on the knees /back and cuts circulation to toes.
It also needs a new guage after only 10 or so times using it. Brand is Cambell- Hausfeld. Just found out why the guage is bad. It says right on the handle 100 psi max. I run 150 on my OBA, whoops.
Bill,
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-12-2012, 01:17 PM   #814
Skerr
The benefit to a rubber shrader valve is that it has a better chance to bend when something rigid hits it, like a branch. The metal shraders are good but they can be pulled out or broken off when a stick gets caught behind it. That has happened to me before. Since your toe circulation gets cut off maybe you should stop using your feet when you air up your tire? Remove the lock on your chuck and it will fit the rubber valve. Sit on the ground (evening up your blood pressure, thus eliminating your pale toe syndrome) when you air up your tires. And have compassion for the guy whose wheels no longer hold air!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 06-12-2012, 05:58 PM   #815
lucdog
lucdog's Avatar
1980 CJ5
If I sit on the ground, my but will get dirty, in turn, that could soil my seats. Then I have to get back up x4.
I have air chucks without the clamp thing. I want to use the clamp,
Like this.
Next time I put air in the tires from 4 to 22/24 lbs. I'll have to check how long it takes.
Since I'm posting again.
I keep my wife happy today. Here's proof!
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-12-2012, 07:50 PM   #816
Jim1611
Jim1611's Avatar
I like the clamp on chuck Bill. Good idea.
I thought your natural charm and rugged looks are what kept Vick happy. I'm not lettin my wife hear about your kitchen remodel cause she's been talking about it lately. Like I need another project!
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 04:40 AM   #817
gmakra
Billy are you sure its your toe that has the circulation problem? The extreme ouddr end of your body does look kinda like a big toe too!
gmakra is offline   Reply With Quote Quick reply to this message
Unread 06-13-2012, 04:44 PM   #818
lucdog
lucdog's Avatar
1980 CJ5
A little vacation did you good George,( I did over 4000 mi. So yours was little.) you came back sharp as a tack, and with a sharp eye.
It only looks that way from the top. You must have been standing on a stool to look at my picture. I saw your picture, send me your address , I'll send you a comb. Your getting close to the Don King look.
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-13-2012, 08:29 PM   #819
Skerr
Nice job on the counter tops. For a moment I thought you had clear ones! I predict wallpaper will be next.
I was thinking, yes thinking. You're STILL going to have to bend over to attach that fine piece of afroasian engineering to the valve stem. Maybe you should get a 3' extension?? I'll bet HF has them already!
Kerrdog
Go Fish! <*////><
Unread 06-13-2012, 09:27 PM   #820
lucdog
lucdog's Avatar
1980 CJ5
Thanks Scott, Vicki picked out the top, she's happy. I didn't care, I thought the 25 year old one was fine, it didn't look wore out.
I think you would need to do the tire filling thing as much as I have, you might feel different about it.
Taking the Grandson camping over by Jim1611. Can't go without a Jeep, so he drove his in and we bungee corded it in.
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-13-2012, 10:19 PM   #821
Skerr
Great stuff, Bill. Have fun Bud.
Kerrdog
Go Fish! <*////><
Unread 06-14-2012, 04:44 AM   #822
gmakra
Bill I prefer to call it Enstien hair. And the counter looks good.
Unread 06-14-2012, 01:24 PM   #823
lucdog
lucdog's Avatar
1980 CJ5
Thanks on the counter.
I talked with Scott after your visit, he said you were a pretty smart guy, so I believed him untill I saw your spelling of Einstein . So I guess it's just the hair!
http://detroitfirefilm.org/. Guys, some really good fire footage in this link from Detroit. There are 3 videos.
Bill
1973 J 4000,
1978 CJ7 DD.
1979 J20
2005 TJ Rubicon.
Unread 06-14-2012, 01:30 PM   #824
benullman
1981 CJ7
Bill
Bill, I was told by one of my mentors, that before he will cut me loose as a full yellow helmet and OIC, i need to go ride in detroit, or baltimore for one shift.
The amount of fire and fatality that exist in these districts is just astounding.
Ben
[QUOTE=Gregg79CJ7304;11634021]Great minds think alike, but so do serial killers......Thanks.[/QUOTE]
benullman is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 03:23 PM   #825
Jim1611
Jim1611's Avatar
Bill don't you get lost coming over here. Don't laugh it happens all the time! All you have to do is blink at the right time and you miss the whole town.
My build thread
